Nitrous in Evo IX
Old Oct 10, 2008 | 11:59 AM
TJung's Avatar
Nitrous in Evo IX
Hello
My Evo IX have a fully rebuilt motor: Ross Pistons AMS Spec., Manley Rods, Clevite, full ARP hardware, 272 Kelford cams.
I would like to install a nitrous kit for my Evo. I have experience with nitrous kits in my latest cars (one had single point system and second was direct port).
Now. How must I install a direct port steering, when I have Flat Shift function?
I mean - when I change gears WITH leg on gas pedal, how throttle body swich could turn off the system?
Any ideas ?
PS. Sorry for my english
Old Oct 12, 2008 | 07:43 AM
justa4banger's Avatar
make sure u have a wideband
Old Oct 13, 2008 | 12:14 AM
red evo8's Avatar
just don't power shift?
Old Oct 13, 2008 | 08:23 AM
TJung's Avatar
Listen. My Evo is full daily driver. I'm running on stock Ecu with EGT & AFR gauges, so I have always engine parameters on eyes.
I am not really sure that my question is clear :/
@red evo8: what U mean "power shift" ?
Old Oct 13, 2008 | 08:26 AM
555R's Avatar
the throttle switch activates the nitrous system
if your foot is on the pedal at full throttle it will continue to spray until you lift off the throttle
or you can put a button on your shift knob and activate it that way
Old Oct 13, 2008 | 11:33 AM
browningderek's Avatar
Originally Posted by TJung
Hello
Any ideas ?
this is simple. wire your relay ground through a clutch switch just like you do a throttle switch. wire them in series so that your throttle switch will be closed @ WOT and clutch must be released for the relay to ground. so if the clutch is depressed it will remove the relay ground even if the throttle switch is pressed.
Old Oct 13, 2008 | 12:08 PM
TJung's Avatar
@555R:
Like I said. I have some experience, so...
ad.1 I know that
ad.2 I thought about this
@browningderek:
Thanks. I think it's the only way too.
I was wondering, that someone did this?
In Poland we have many modified Evo's, but nobody have nitrous kit. I think they are scared of nitrous in Evo.
I was very glad my nitrous kits earlier, so I wanna try this in Evo too
Old Oct 13, 2008 | 12:35 PM
ch53avitech's Avatar
I don't think Evos respond well to nitrous. Evo usually respond better to alky/meth.
Old Oct 13, 2008 | 01:21 PM
Duh Panda's Avatar
anything responds to nitrous "well"
low intake temps... more timing .. etc
cmon now bro
Nitrous! best BANG for the buck
Old Oct 13, 2008 | 02:33 PM
importjake00's Avatar
Oh yeah, fast and the furious style yo!
Old Oct 13, 2008 | 02:34 PM
Billy@EnglishRacing's Avatar
make sure you have a good tuner
Old Oct 13, 2008 | 02:39 PM
prodigalsunn's Avatar
i bet all the pro street drivers running low 7's and 6's would love that comment
Old Oct 13, 2008 | 09:50 PM
TJung's Avatar
This my latest car:
http://www.streetracing.pl/forum/Sea...or-t45127.html
All mechanical modifications was did by myself.
And this is my Wife car: Fastest Mini in PL:
http://www.streetracing.pl/forum/Mal...-S-t51421.html
Maybe now some users will taking me serius.
Old Oct 13, 2008 | 10:49 PM
EvoIXJDM's Avatar
Just buy a ZEX nitrous wet kit with a window switch and use maximum 75 hp with a good tune.
I use it regulary at the track.
Old Oct 13, 2008 | 11:25 PM
TJung's Avatar
Thanks. I had ZEX in my earlier car. I have read about this "window switch" and wondering it could help me.
Can U tell something more about connection and steering system with this device ?
It could be on PM.
Are You using a FlatShift ?
