Nitrous in Evo IX
Old Oct 14, 2008 | 06:25 AM
EvoIXJDM's Avatar
The connection es very simple, you have first to connect the nitrous module with have the solenoids, this is activated with a voltage signal from the tps, one of the 3 cables, I dont remenber exactly which is, but with a voltmeter you can determine which is.
Then you have to "program" the module with your throttle pedal and thats it.
Later you have to install the zex window switch, and have to cut this wire that you previously connected to the tps, this two pieces of cable go inside the window switch.
Then you have to program it, is a very complete unit, because you can activate it, to start at first, second or what ever speed you want, it do this because you also put the start and end rpms.., when you achieve the first time the end rpm it activates.
If you have any other question, you can ask me and I help you without problem.
Old Oct 14, 2008 | 06:34 AM
dahuii77's Avatar
please dont blow your engine with that nitrous ...........good luck then........
Old Oct 14, 2008 | 12:20 PM
TJung's Avatar
Thanks very much. Your info is very helpfull for me.
ASTROEVO
36
Mar 6, 2014 12:46 PM
Dragking2189
22
Aug 25, 2011 04:36 PM
datrip
22
Feb 15, 2008 11:55 AM
drewblueeye
Sep 11, 2006 03:01 PM
Ralli04Art
13
Jun 8, 2006 08:24 PM
