Turbo Suggestions for EVO IX
Old Oct 12, 2008 | 09:25 PM
acid668's Avatar
Question Turbo Suggestions for EVO IX
Hi guys.. Need a good recommendation evo 9 Turbo... Stock Block oversized pistons..
As my Stock turbo just went boom on me...
Appreciate for any feedbacks..
Old Oct 12, 2008 | 09:36 PM
vtec2mivec's Avatar
everyone's going to tell you to search...there's plenty of threads on this. But it depends what you want from your car and what you'll be doing with it. A good step up from the stocker and a great turbo would be the FP Green, won't get you crazy hp but won't be too laggy.
Old Oct 12, 2008 | 09:40 PM
sparky's Avatar
I have the Green but will be moving up to the Red as soon as the piggy bank is full or I get a bigger allowance. Did you have the stock IX turbo or the JDM magnesium RS turbo? Go Red, if spool is an issue get the Red with a 9.8 turbine housing. The Red is one nasty turbo.
Old Oct 12, 2008 | 09:51 PM
acid668's Avatar
I have the JDM magnesium RS turbo... The turbo just gave up on me as the magnesium fins broke... Therefore i am looking for a better turbo which lasts..
Old Oct 12, 2008 | 10:12 PM
sparky's Avatar
You started two very similar threads. You will probably get punished for being redundant
Old Oct 12, 2008 | 10:26 PM
beemerfreak's Avatar
FP Red/End Thread.
Old Oct 12, 2008 | 11:08 PM
speedypollard's Avatar
CBRD BBK is better than the FP green in every way
Old Oct 12, 2008 | 11:50 PM
sparky's Avatar
The BBK's compressor flows less air than the Green's compressor(47 lbs. vs. 49 lbs.) doesn't it? We should wait on the BBK's track results before forming any definitive conclusions.
Old Oct 13, 2008 | 12:18 AM
DIDYSIS's Avatar
HTA GT35R cant go wrong with it, power, fast spool, tons of fun
Old Oct 13, 2008 | 12:21 AM
WWEVO206's Avatar
FP Red or HTA GT35R.
Old Oct 13, 2008 | 05:28 AM
CBRD's Avatar
our turbo is 47-48 lbs min.....
you have a couple of good options now for stock housing turbos.... if your goal is to run over 30psi... use the red.... pump gas... 20-29psi range is where ours works best....
We designed this turbo with the street/road racer in mind... we arent a drag racing company.... our turbo was built for power delivery, response.....
cb
Old Oct 13, 2008 | 11:59 AM
Shacochis06's Avatar
Red Ftw
Old Oct 13, 2008 | 12:15 PM
ForcedPerformance's Avatar
If you are talking about turbos that are for sale and being produced, you have a few different options.
First there is the +1 level, the FP EVOWhite, this has a 47lb/min HTA compressor wheel in it coupled to that stock TD05H turbine wheel, best spoolup out of all with the advantage of 5lb/min over the stock turbo.
Second is the +2 level with the FP EVOGreen, this is a 49lb/min compressor with a larger turbine wheel, good spool but 420whp+ capable andf tons of cars running around on it in the 10's, proven product without equal in the market.
Third and probably the most significant of all three is the FP EVORed, 60lb/min with an even larger and improved efficiency turbine wheel. Runs 9's on at least 3 cars and the turbo has only been available for a few months.
There are other vaporware products shown in online catalogs, blogs etc, none commercially available to my knowledge. And more importantly none running any impressive times anywhere. If anyone has seen other stock appearing turbos run fast anywhere please correct me.
Old Oct 19, 2008 | 03:40 AM
acid668's Avatar
Hi thanks for your input... But then if i was located at the other side of the world.. As i am in Asia... How long will the shipment take if i were to order an FP Green from your side?..
Old Oct 19, 2008 | 06:08 AM
CBRD_Caleb's Avatar
Be sure to ask many questions and talk to people with different combinations.. make sure you get the turbo that best fits your needs
good luck
