viii block ix head
Lets see 2.3L Evo 8 block turned into an Evo 9 Block 10K miles Ago, hta 35R on it, everything is fully built, I drilled it and cleaned it very well, not a problem at all with anything. I would do it again any day. Then again once you do something once its always easier to do it again. If you have any questions ask away. I drilled the block upside down so all the metal fell to the ground not inside the block, and then I used a small pipe cleaner to clean anything extra when I tapped it. I think the pics explain it well. But if you need anything as I said ask, I am proven to make lots of power and no oil leaks from this setup. I love my car.
Thought I would update this thread. I recently took this car to the track. The mods are 3" TBE, cone filter, MBC, and E85. Also running a walbro 255, and 1200cc injectors. Road tuned by me.
UPDATE AGAIN
I ran an 11.9 @ 115 on fourth of july weekend. New best
Best run was a 12.16 @ 114 with a 1.76 60ty
In my last run I had an intercooler pipe blow off at the end of the track and still ran a 12.14 @ 110 with a 1.72 60ty.
I did cut a 1.68 60 ft earlier, but missed 2nd gear like an idiot.
Again, this is a evo 8 block with an evo 9 head.
UPDATE AGAIN
maikcat
Feb 19, 2016 01:57 PM
Mivec2.0
11
Dec 28, 2011 08:53 AM
N33d4sp33d
28
Feb 9, 2010 01:30 PM
