Clutch grinding at take off
Old Oct 19, 2008 | 04:20 PM
J8dailo's Avatar
it seems like whenever i let my clutch out and give it some gas while im taking off from stop light...it makes a horrible grinding noise...it been doing it for a while now.... i had my clutch replaced few months ago... i tried adjusting the clutch pedal a little bit and helped slightly but still grinds... im running exedy stage 2 clutch.... i heard running extended slave cylinder rod might help...can anyone fill me in on this???
Old Oct 19, 2008 | 04:24 PM
bevolucion's Avatar
sounds like a bad throw out bearing. might want to check it out, maybe a bad installation.
Old Oct 19, 2008 | 04:26 PM
gixxer6's Avatar
hmm mine doesn't grind but when its cold it makes like a creaking noise..like a metal hinged door or something+1 on some help? hope you don't mind me sharing my problem on your thread
Old Oct 19, 2008 | 04:39 PM
J8dailo's Avatar
i remember i made a thread a while back...i had it installed at devo tunning...i think they might reuse the stock throwout bearing with the exedy stage 2...... if this is the case...bad throw out bearing...what other problems can accumulate from this other than grinding noise???
Old Apr 17, 2009 | 07:57 PM
brandon1304's Avatar
bumppp.... i have the same problem.... any solution??
rupp003
33
Aug 29, 2013 10:26 AM
Harumsevo
Jul 30, 2013 05:19 PM
Tevo9K
Mar 28, 2011 10:52 PM
italianevo88
Sep 7, 2009 07:14 PM
bruce988jl
20
Oct 25, 2008 02:24 PM
