Testing new Wavetrac front Diff...
Old Feb 18, 2013 | 01:49 PM
  #31
KOOLER's Avatar
I'm looking for a replacement of my open diff. Price for Quaife and Wavetrac is the same. What should I get?
PS Clutch plate diffs are SO much more expensive
Old Apr 10, 2013 | 06:39 PM
  #32
spinner85's Avatar
I'm getting my t-case from shep in a couple weeks. It'll have a Wavetrac in it
Wavetrac provides tension even at zero load. And made in the US.
Quaife has been around for a long time and has a better rep.
Either one will be better than the stock diff and probably won't notice much difference between the two 90% of the time it's in a daily driver.
Good luck
Old Oct 18, 2014 | 06:26 PM
  #33
EvoTurboTurk's Avatar
Does this replace the transfer case or fit it inside? Does it strengthen it & can be used for launching
Old Oct 18, 2014 | 09:57 PM
  #34
AreSTG's Avatar
goes inside the tcase. much stronger than the standard setup, and without a doubt can be used for launching, many many times.
Their customer service is TOP NOTCH as well.
Old Dec 2, 2014 | 07:11 PM
  #35
ROB-80E's Avatar
What's peoples impressions on this unit in the wet?
Particularly interested in whether grip in the wet is comparable to standard diff.
Ta.
Old Dec 3, 2014 | 10:28 PM
  #36
ReidFletcher's Avatar
Ta.
Besides the Wavetrac being hands down the best mod I've done to any car that I've owned, I've been driving my evo for the past 2 days in the rain and it behaves much better than the oem diff naturally. It takes little effort to pitch the car to oversteer in the wet to the point where your scaring the public. I can't comment on the stock diffs wet performance exactly as its been too long to remember, but from remembering the night and day difference when i installed the Wavetrac I'm gonna say the Wavetrac is an immense improvement in the wet.
Old Dec 5, 2014 | 06:13 AM
  #37
AreSTG's Avatar
Ta.
what standard diff? not sure about overseas, but depending on year and trim we had a handful of diffs from the factory here.
Old Dec 6, 2014 | 07:01 PM
  #38
I noticed it says Evo 8 & 9 Wavetrac front diff, would this fit the JDM Evo 7?
Old Dec 7, 2014 | 07:19 PM
  #39
ROB-80E's Avatar
Ok thanks. I've only driven the car a couple of times in the wet now...but have to say my impression of wet performance is that I've lost front grip. Considerable amounts of understeer.
My car had the JDM transfer with Torsen LSD and ACD....if I take that as a 0 (zero) baseline, dry performance has increased by +20 with the Wavetrac. LOVE IT! However, wet performance feels like it's gone to -15 with the Wavetrac. Off throttle grip is good in the wet...however when you apply throttle to accelerate, the front just slides.
Old Dec 14, 2014 | 09:34 AM
  #40
Ang Wen Yan's Avatar
Yes it will fit
It's the same T Case
Old May 4, 2015 | 09:03 AM
  #41
Evopower88's Avatar
any update of this lsd? i always use quaife with any problema, but i want to try this wavetrac; someone can help me
thanks
mrfred
Oct 8, 2020 03:49 PM
Dallas J
Sep 10, 2019 11:45 AM
maxroach
24
Jun 13, 2017 03:18 PM
MurtazaDSM
Dec 17, 2016 11:05 AM
Kevin Troy
May 1, 2016 02:43 PM
