Which BOV to use APS dual vent or another?
Old Oct 27, 2008 | 02:51 PM
Johnboy1065's Avatar
I used to have APS and loved it. that was in my stock turbo days but I only upgraded to a tial because I didnt have to satisfy the ECU anymore when I went to speed density
Old Oct 27, 2008 | 02:53 PM
fugiwara's Avatar
Originally Posted by JYoungEVO
go with a recirc bov that way you dont have any chance of stalling out....
APS is recirc bov, it uses stock location. What makes you think it is not recirc bov?
APS will never stall out, b/c it recirc, it only vent partial pressure out. Look at the design of APS bov and you'll understand.
Old Oct 27, 2008 | 03:06 PM
Evoryder's Avatar
mellon should update his original post
Old Oct 27, 2008 | 04:26 PM
k2boarder3187's Avatar
APS ftw!!
Old Oct 27, 2008 | 05:39 PM
I4UnderPressure's Avatar
I ran the APS Dual vent on my WRX when I had it and it is an excellent blowoff valve! Not sure if you will be recirculating, but under higher boost levels it will blow off the higher pressure to the atmosphere while under low boost levels it will recirculate to the intake. I called it the "smart" BOV. But I am new to this community so whether that on an EVO would work well or not is another ballgame.
Old Oct 27, 2008 | 09:47 PM
mrfred's Avatar
From what I've read, there are two good options:
1) APS dual vent - Gets generally excellent review, but a few people have complained that it needs frequently cleaning (every 5K miles) to provide good performance.
2) Stock Evo IX DV with a Dejon Stop Leak Kit. This has all the driveability of the stock DV, but with extra boost holding capacity (easily to 30 psi).
Option 2 is about $50 cheaper, and the Evo IX DV is a proven daily driver performer, so that's what I bought. Haven't had time though to install it to provide a review.
Old Oct 27, 2008 | 10:04 PM
justa4banger's Avatar
aps ftw
Old Oct 28, 2008 | 09:31 AM
Mellon Racing's Avatar
Originally Posted by Evoryder
40psi? You tested it on a bench also?
no, I'm saying my car had no problem zinging up to 40psi with it. I run 32.5-34.5 daily
Old Oct 28, 2008 | 11:33 AM
Evoryder's Avatar
What's a zing ...
I wish you had updated your original thread. I leaned towards the Forge because you said it held more boost than the aps. Your reviews are like the holy grail ...THe forge really does drive like a$$...part throttle it's like a roller coaster.
Old Oct 28, 2008 | 11:35 AM
What's a zing ...
I said the forge holds more boost than the APS if that was the case it was because I had in in backwards
Old Oct 28, 2008 | 12:55 PM
03redtype-s's Avatar
decision made aps it will be!
Old Dec 1, 2008 | 05:40 PM
xxJxx's Avatar
aps is the way to go
Old Dec 1, 2008 | 07:47 PM
MitsuJDM's Avatar
Just to make it clear. The APS BOV NEVER vents 100% atmospherically. Unless you're at full boost, depending on how stiffly you have it set, it will only vent as much as 50% or lower atmospherically.
Old Dec 1, 2008 | 08:33 PM
aka.ralliart15's Avatar
Update: Running 28psi no problems, holds like a champ. I'll be running 32psi next week i'll keep you updated.
Old Dec 1, 2008 | 08:35 PM
TurboTodd's Avatar
APS is the way to go. I'm surprised that the Forge was even considered. It's worth the x-tra cash. Driveability is superior!
Todd
