Which BOV to use APS dual vent or another?
Go with APS, holds boost like a charm, am boosting 27.5psi, gonna take it higher soon but not now need new spark plugs
and Mellon did a great review about the APS check it out
https://www.evolutionm.net/forums/sh...d.php?t=308210
This is true. While running this on my WRX a while back, I was running 20psi. If I had her floored and let off at 20psi, she would vent atmospherically hard like a compressor fitting popping off. (nice and loud) but under partial boost, it would recirculate just like stock. Personally, I loved the APS when I ran it.
+1 for the APS. Had it almost 4 years now and still love it!
Also, if you look at the design of it, you can see that it will never fully vent VTA. Depending on the boost level, the plunger will move appropriately and either dump to one port or to both. But not one or the other.
it really is a fantastic BOV and I'm so glad I stumbled upon it awhile back. I've been regularly boosting to 30-35psi without any problems. It drove perfectly when I was at 400awhp and it still does at 600awhp. It's quite possibly the only BOV you'll ever need.
Sorry to bump but, I was reading about tefflon taping the spring. Would you need to do if your only running 24psi? Im looking to buy this BOV to try to solve a idle problem im having on my Stock 9 DV.
IX is good for 25psi max...anyone that says other wise is lying or not testing properly. If it could hold 30psi before leaking most would never upgrade...
https://www.evolutionm.net/forums/sh...&highlight=aps
I don't have a log in for that forum
APS all day everyday. i will be going to that bov most likely with my set up. buddy used that on his set up and had no problems with high boost 28+psi. u can recirulate it for the great driviblity. i have done a good amount of research on that DV and hands down one of the best on the market
I have the Forge adjustable recirc, I get hard compressor surge if I try. I could most likely turn it down a little so that it releases the air a little smoother, but it is fun freaking out friends with the chewbacca noise (what they call it). If I don't try to surge, spool then go to partial throttle, it drives perfectly. You can flip it 2 ways to have it make 2 different sounds, if anyone cares; thought I put it on the wrong way, and discovered it is reversible.
-Will
-Will
From what I've read, there are two good options:
1) APS dual vent - Gets generally excellent review, but a few people have complained that it needs frequently cleaning (every 5K miles) to provide good performance.
2) Stock Evo IX DV with a Dejon Stop Leak Kit. This has all the driveability of the stock DV, but with extra boost holding capacity (easily to 30 psi).
Option 2 is about $50 cheaper, and the Evo IX DV is a proven daily driver performer, so that's what I bought. Haven't had time though to install it to provide a review.
how does the turbosmart BOV fair in this post...just curious
the dejon kit sounds like a good idea but the thought of possibly ruining the stocker
doesnt go well with me
unless they offer the service
Not yet, I kinda put hardware mods on old for a little while because of winter. I'll probably do it some time in late-Feb or after I come back from vacation in late March.
I've had my used APS twin vent for maybe a year now, haven't needed to adjust or clean it, still very happy with it. Boosting to ~33psi daily and that's not some brief spike, that's to redline ~ 8-9k
