cam installation vibration
Old Oct 28, 2008 | 09:15 AM
Gary@MellonRacing's Avatar
Unhappy cam installation vibration
we insatlled a pair of hks 264-272 and adjustable cam gears put to 0 on my friends evo 2004 evo 8 after this we have noticed a lot of vibrations from the motor big time , u can feel that it vibrates a lot , this had not happened before the install , anyone with info on this.....
Old Oct 28, 2008 | 09:38 AM
RoadSpike's Avatar
Means your balance shafts are not in sync I had the same problem the first time i did the belt.
If you didn't do the smaller belt balancer belt then likely its the outer balancer belt/ oil pump pulley. The evomoto instructions on changing the timing belt include the methods for getting the pulley in sync.
Old Oct 28, 2008 | 12:09 PM
thats the thing the car has the balancer installed correctly and belt correctly
Old Oct 28, 2008 | 12:12 PM
ROAD RACE VR-4's Avatar
Go back and double check your work. You messed up somewhere.
Old Oct 28, 2008 | 12:28 PM
RoadSpike's Avatar
Obviously not if its vibrating like that. From my understanding the balancer is geared so even if the timing marks line up it doesn't mean its in sync. There is a spot where you stick in a screw driver to check the balancer timing.
The spot is behind the o2 outlet and a little to the passenger side. There should be a flat spot with a 14mm bolt in it. Undo the bolt and slide the screw driver in. If the screw driver can go in and its on the timing mark your golden.
BTW when i screwed up my install the vibration started around 3500rpm and would practically rattle the whole car.
Old Oct 28, 2008 | 05:49 PM
thanks man
Old Oct 28, 2008 | 08:50 PM
jeri534's Avatar
How would the timing of the balance shaft be messed up when installing cams?
Not trying to say anything just wondering for myself.
Old Oct 29, 2008 | 12:21 AM
RoadSpike's Avatar
Both timing belts are connected to the balancers so if they are out of sync or off then they would cause the above.
Old Oct 29, 2008 | 07:16 PM
jeri534's Avatar
nm
girth5785
Jul 27, 2016 08:27 AM
g7igo7
12
May 11, 2016 08:33 AM
TommiM
15
Sep 30, 2014 04:46 PM
johnnnyjeans
Jan 1, 2013 10:39 PM
EvoNick
15
Oct 10, 2005 03:13 PM
