Fuel pump hickup!!
Old Oct 30, 2008 | 10:01 AM
Waz996's Avatar
Fuel pump hickup!!
Hi guys..
I'm done with my new build (details below..)
All is set and I'm breaking in the new block for the next few thousand km's...
I have a slight problem though,, the fuel pump no.1 which is connected to ECU wiring (pump no.2 triggers via a boost switch) goes on and off intermittently at idle.. Onlyat idle,, when the car runs normally, my fuel pressure is very stable and rises normally as the boost kicks in..
Of course I had to cut the fuel pump casing to fit both walbros in.. And there's this little wire that I've cancelled that can be some regulator? Is it why the first pump is having this hikcup problem??
Comments appreciated!
Wael
Old Oct 30, 2008 | 11:38 PM
Waz996's Avatar
Bump Bump!??
Anyone! Help an ailing Evo!
Wael
Old Oct 30, 2008 | 11:43 PM
RoadSpike's Avatar
Sounds like a problem with the switch. Why a boost switch btw?
David's double pumper uses a fuel pressure switch since the pressure goes up 1psi per 1 psi of boost you can just trigger on the pump that way once its gets up a ways past the stock 40 or so psi.
Old Oct 31, 2008 | 02:09 AM
Waz996's Avatar
Tx for reply Spike,
Ya it's exactly what i got, a boost switch that triggers pump-2 when the turbo boost rises above 15psi.. So above 15psi, the two pumps are working, for safety.. Pump-2 is connected external to the ECU wiring, it just triggers on with the boost rise..
The problem I have is with pump-1 only, it just switches on and off (about 2times per second) at idle only..
Wael
Old Oct 31, 2008 | 10:17 AM
RoadSpike's Avatar
Originally Posted by Waz996
Tx for reply Spike,
Wael
Ah i see was totally confused there.
what kind of pump is it? If i remember right the Ecu wired pump does this resistance thing lowering the voltage when the pump is at idle. Perhaps that could be the issue and thus the fix would be to connect up pump 1 directly up to the fuel pump relay?
Don't take my word for it though this is just a guess
I would take a volt meter out there and see if something odd's happening to the voltage and work it out from there
Old Oct 31, 2008 | 10:47 AM
Waz996's Avatar
Exactly,, I know for a fact that there's an ECU 'Low pressure' / 'Hi pressure' ECU order depending on the need..
And i know that pump1 is intermitently shutting off because i can feel it and hear it whininig on and off..
Would it be fair to wire the pump-1 directly on external relay and bypass the ECU?
Wael
Old Oct 31, 2008 | 10:50 AM
RoadSpike's Avatar
Wael
With your problems i would but first take a volt meter to it maybe its something else
Old Oct 31, 2008 | 11:40 AM
Waz996's Avatar
OK,, will do tomorrow (it's 1030pm here!)
Thanks.,,
Wael
mrfred
383
Jul 16, 2024 09:29 PM
kaj
26
Jan 4, 2017 09:33 PM
stiffdogg06
19
May 28, 2015 08:33 AM
Mark_L
Jan 4, 2014 03:56 PM
duranvw
Dec 2, 2013 12:05 PM
