Kelford TX272's
Old Oct 30, 2008 | 04:02 PM
Tonba's Avatar
Kelford TX272's
Hey All.
Im looking at getting some Kelford TX272's, and adjustable cam gears.
But my tuner/mechanic seems to think that it will be no good on the stock valvetrain as they are potentially too aggressive.
He believes that profiles no bigger then the HKS range should be put on an Evo 8 with stock valve train.
Be believes the Evo 9 valve train is fine for Cosworth M2's, etc but the Evo 8 is restricted to HKS?!
I have no intrest in running over 7000rpm at all, and will probebly get my tuner to set my rev limiter at 7200rpm just in case...
Thoughts? Does anyone else these are too aggressive for the stock valve train?
Regards,
Alex
Old Oct 30, 2008 | 04:10 PM
AWD Motorsports's Avatar
I personally dont think youll have an issue with the Kelford 272's on stock valvetrain.. You could always drop in some GSC beehive springs with stock retainers for extra peace of mind.. We have sold that combination to several people with great success.. Any questions feel free to PM me..
Mike
Old Oct 30, 2008 | 04:18 PM
1NASTYIXMR's Avatar
If your worried about the stock valvetrain just upgrade it, its not that big of a deal.
Old Oct 30, 2008 | 04:34 PM
Tonba's Avatar
My mechanic also believes that on the evo 8, you cant just 'drop in' springs. You have to modifey the spring seats... >_<
more $$$
Old Oct 30, 2008 | 04:38 PM
more $$$
Well, we have done time and time again in several 8's and 9's.. you can just drop in springs and cams and youll be set.. I am not sure if you meant modify Valve seats or spring seats but if you want a valve spring kit with locators we have those too if it makes him feel better..
Mike
Old Oct 30, 2008 | 04:40 PM
vvhiteix's Avatar
on "most" 272 cams you should be alright if your not revving above the stock rev limiter.
Old Oct 30, 2008 | 04:41 PM
1NASTYIXMR's Avatar
sounds like you need to find a new mechanic. lol But really he is just trying to do it the right way, i would just save up and then get it done.
Old Oct 30, 2008 | 05:33 PM
Tonba's Avatar
Ok guys.
Another call to my mechanic.
Apparently my car does not run the same valvetrain configuration as your cars.
The USDM Evo 8 head is based off an Evo 7, which uses fully size valve springs.
The JDM Evo 8 Head uses a tapered spring design, which means to fit aftermarket springs, I DO need the spring seat to be modifiyed and I also need retainers to suit...
Hmmmm.
Old Oct 30, 2008 | 06:05 PM
Ok guys.
Hmmmm.
I have Ferrea Springs, Retainers, locators and locks as a kit if you need.. Itll give you and the mechanic peace of mind..
Mike
Old Oct 30, 2008 | 06:10 PM
Tonba's Avatar
Im not too keen on doing all of that just of yet. I jsut want to drop in some cams..
Will do giving the head the works when timing belt is due.
Port/Polished
New Valve Guides
Springs/Retainers
New Spring Seats
New Timing Belt
I hope that the Kelfords are not too wild for the standard valvetrain...
Old Oct 30, 2008 | 07:01 PM
Port/Polished
New Valve Guides
Springs/Retainers
New Spring Seats
New Timing Belt
Its not like you have to take the head off to do springs and retainers.. it takes a few hours.. The head stays on the car...
Mike
Old Oct 31, 2008 | 06:48 AM
xexitenglishx's Avatar
I have the kelford 272s on my car. Its an evo 9 but i left the stock valvetrain intact and i dont rev about the stock rev limiter. Sean Ivey said it should be fine and i trust him
Old Nov 5, 2008 | 06:51 PM
Tonba's Avatar
Ok Guys. I bit the bullet.
Kelford TX272 + Fidanza Adjustable cam gears on the way. Hope these will make me some good power.
Im also pulling the stock rev limiter back to 7,100rpm as a 'just in case' measure as the stock valve springs on the JDM 8 are very poor.
Hopfully they will make better power then HKS 272's.. Even On a mildly Modded Car.
My Mods are;
-Flash Tune
-HKS EVC 6
-Walbro 255l/hr
-Gruppe M Ram Air intake System
-Hypertec Suction Pipe
-Modified J Speed Twin Dump + Front Pipe Setup
-MIL.SPEC 100 cell Cat
-Custom 3" Stainess Cat-Back Exhaust
Old Nov 5, 2008 | 07:01 PM
fugiwara's Avatar
https://www.evolutionm.net/forums/sh...ht=kelford+272
just search, I found a few threads dedicated to your topic, I was looking at them this afternoon
Old Nov 5, 2008 | 08:06 PM
Tonba's Avatar
^ That topic doesnt really apply to me, as I own a JDM Evo 8. The JDM head design is much different to the USDM head.
The JDM uses a Cone like spring and the USDM does not as it is based off an EVO 7 head.
Thanks for the link though. It is a very informative read.
Im going to ask my mechanic/tuner if he can locate any drop in springs for a JDM E8. If not, Im just going to have to run standard valvetrain and rev limit to 7,100rpm..
chaotichoax
Apr 12, 2020 11:55 PM
MisUnderStood
Jan 27, 2017 10:11 AM
3bar_dc2
Aug 6, 2015 10:08 PM
Boostin4g63
13
Apr 14, 2008 06:05 PM
RyanM
28
Jun 20, 2006 12:21 PM
