Help! Check Engine light/bogging after 4k rpm
Old Sep 4, 2003 | 11:49 AM
Deceit's Avatar
The SAFC is working, but I noticed my check engine light went on and the car seems a whole lot more sluggish. Also, after I get to about 4,000 RPMS my car feels like it got hit in the stomach and loses it's push and feels like it's bogging. Also the car doesn't sound like it used to. What's the prob? Any ideas? Is there some safc settings I should be putting in or something?
EDIT: used the field harness if that helps.
Old Sep 4, 2003 | 11:51 AM
yycools's Avatar
try take the afc off and run it for a while, if eveyrthing went back to normal, then its your settings. From the sound of it, you prob lean out too much at around 4k.....
USP45's Avatar
Check all of the hoses associated with the turbo and intercooler system. Sounds like one blew off and you are not getting into boost because the pressure is escaping, just tighten it back up and see what happens.
Old Sep 4, 2003 | 11:54 AM
stvbreal's Avatar
Check to make sure the "Sensor Type" is set the Karman.
And "Car Select" is set to 4.
Old Sep 4, 2003 | 12:03 PM
Deceit's Avatar
yepo, it was the karman sensor that fixed the rpm problem. I already thought it was set to karman, but that's ok. The Service engine soon light is still on though. any ideas bout that one?
Old Sep 4, 2003 | 12:33 PM
Insidious Evo's Avatar
Try resetting the comp. Re move the negative on the batt. for a couple of minutes. Hope this helps.
-Erik
Old Sep 5, 2003 | 08:21 PM
Deceit's Avatar
worked. dankee for everything guys .
now who wants to get me those "sweet spot" settings for a modless evo
Lombardi23
Apr 22, 2016 08:15 PM
noubey27
16
May 18, 2015 06:48 AM
haloevolution45
24
May 10, 2013 08:46 PM
evo noob
Sep 30, 2006 11:28 AM
KY
Jan 29, 2006 07:49 PM
