overkill?
Old Nov 1, 2008 | 06:29 PM
house_of_senate's Avatar
Originally Posted by SLOBRA
Personally I believe it's over kill because you have a motor that's capable of 800+ HP and your going to put a stock based turbo on it... You should definatly push the motor to the limits. Just my $.02
They red may be a stock BASED turbo....But far from a stock turbo.
Old Nov 1, 2008 | 06:32 PM
wevo1985's Avatar
i learn from my mistakes. i shouldve built my motor sooner and now i have to spend more than i wouldve last year, and i had to get towed home when all my friends still went to the track. i say build when you have the chance.
Old Nov 1, 2008 | 06:33 PM
AWD Motorsports's Avatar
Yep, its always much more expensive to build the motor when you blow up the good core you could have used.. Live and learn..
Old Nov 1, 2008 | 06:51 PM
wevo1985's Avatar
its also alittle imbarrison and upsetting at the same time.
Old Nov 2, 2008 | 01:53 PM
ch53avitech's Avatar
How hard is it do a swap like that, like getting the engine built, hooking up the wire harness, and such? Does it take a lot of measuring and calculations to get the motor put together? Or is it as simple as this: http://www.youtube.com/watch?v=CvNpyF6YM7o
Old Nov 2, 2008 | 01:58 PM
wevo1985's Avatar
i would rec. to have all the measuring done that way you know everything is going together properly. if the clearences are too loose or too tight youll loose the bearings. than youll have to do it again. should do it right the first time.
Old Nov 2, 2008 | 02:16 PM
LoKiEvo's Avatar
Go ahead and send it out to Buschur... I had my motor rebuilt by a shop (not gonna metion names) that was not EVO specific... lets just say, Its 9 months later and I have to rebuild it again... Had I just gone with Buschur the first time... I would still be good.
Old Nov 2, 2008 | 02:23 PM
Can I just hand them 10 grand and tell them to just build a nasty motor?
I don't know much about rebuilding motors, I've always just stuck to bolt-ons. I'm mechanically inclined, I work on CH-53's.
Old Nov 2, 2008 | 02:34 PM
wevo1985's Avatar
https://secure.buschurracing.com/cat...526430681cbe9e
heres some links for motors and heads through them. you just need to send a good core in return.
Old Nov 2, 2008 | 02:52 PM
equinsu-ocha's Avatar
Originally Posted by Mike@AwdMotorsports
No way is it overkill.. With the potential of 140+ trap speeds for an FP RED.. Who wants to be limited to 500hp with a red when they can make 600whp?? We are doing a Buschur 2.3L + Red this month.. I think thats the ultimate setup.. The Red doesnt make much power over 8k and the Stroker is limited to 8500 so the low end it will bring into the equation will be awesome.. Ill keep you guys posted!!
Mike
Keep in mind that the 2.3 flows as much air at 8k as the 2.0 does at 9k rpm.
Old Nov 2, 2008 | 04:27 PM
LoKiEvo's Avatar
What Branch and where are you stationed? I was in the Marines, AVI tech on Hueys and Cobras stationed at New River.
Anyways.... like I said before send the motor to Buschur, they are by far proven to be the best.
Old Nov 2, 2008 | 04:34 PM
Sharkbite2000's Avatar
BR stage 3 couldn't never be over kill it's just right
Old Nov 2, 2008 | 11:48 PM
Whoop_ass's Avatar
secom that...
I am soooo happy with my BR stage 3 long block.
it never over kill, rather over engineer something than under...
Old Nov 3, 2008 | 10:49 AM
Marine Corps, Avi Tech on 53's, stationed on New River.
Old Nov 3, 2008 | 10:56 AM
Originally Posted by Whoop_ass
secom that...
Whats the difference between the short block and the long block and why isn't it here https://secure.buschurracing.com/cat...d3da61a1401cc7 ?
