overkill?
Theres always room for a bigger turbo if you wanna go faster. put the red on the built motor if its not enough u could go to a 35r or even bigger and not have to worry about your motor...do it right the first time...go for it. if i had the money id do it.
Like everyone is telling you...go for it man good luck with the build!
not overkill at all, better to be safe than sorry and you can always upgrade to a bigger turbo when the red gets old.
Never overkill. The more you "over build" the less likely you'll pull it back out 5 times to upgrade. The reds love boost, with a fully built motor you can run some high boost. Do it!
