Low voltage causing mis-fire?
Old Nov 2, 2008 | 05:28 PM
DG Motors's Avatar
Hey guys i am experiencing weird misfires. I have a fully built evo 9 with an aem ems. As far as iginition goes i am using: buschur mini-battery, hks dli2, and ngk lfr6a11 plugs. Now before we go crazy, i am also using a buschur double pumper, aquamist alcohol injection, and a few gauges hooked up to the mini battery.
My question to the community is what is average battery voltage during a single 3rd or 4th gear pull? Using aem to log, i currently see 11.15-11.30 volts throughout full boost.(42psi)
My current tune is spot on,plugs have been changed and gapped to .022. c-16 and 42psi breaks up horribly. I even went as low as 32psi and it is the same. One pull can be fine, the next breaks up, and so on.
I am going to assume everyone is telling me the hks dli2 is crap and i should get a COP which i am ready to pull the trigger and order one asap.
Thank you for everyones input, my main concern is average battery voltage with the above mods i have listed above.
Old Nov 2, 2008 | 05:32 PM
1d10t's Avatar
Can not expect a good ignition with low voltage. Make sure that your alternator is working properly.
Old Nov 2, 2008 | 06:10 PM
DG Motors's Avatar
There is only 15,500 Miles on the alternator, its original. I have only heard of one other instance but i believe the alternator was older.
Old Nov 2, 2008 | 06:12 PM
DG Motors's Avatar
Can anyone give me battery voltage readings on a 650-750whp build?
Old Nov 2, 2008 | 06:51 PM
03whitegsr's Avatar
I think the goal would be to keep battery voltage as consistent and near 14V as possible.
A local kept losing motors because of a similar issue from voltage drop. The voltage dropout would make the fuel pressure drop in an unpredictable manner and cause ignition misfires.
He finally went up to a higher current alternator and has had much more consistent results since.
Old Nov 2, 2008 | 07:07 PM
SLOBRA's Avatar
Battery voltage should be the first thing you should look at when diagnosing that kind of problem. It looks like you have found the problem with the question in your first post. 11 V is way to low, looks like your alternator isn't even working.
Old Nov 2, 2008 | 08:17 PM
fimotorsports's Avatar
thats a bit low, but also the aem reads the voltage about .50 lower then it actually is from what I heard. I had similar issue with mine since my fuel pump takes so much amp's. Once I fixed the voltage to be in the 12's, my afr's dipped into the 10's.
I would try switching the battery and logging the volts again. If that doesn't fix your misfire I would consider changing to a cop.
Old Nov 2, 2008 | 09:56 PM
DG Motors's Avatar
I appreciate your input. I did run two batteries in parallel with each other on the dyno and it did not make a difference. I am considering the alternator is shot but i haven't heard of this before at all. Thanks again
Old Nov 2, 2008 | 09:58 PM
DG Motors's Avatar
I am going to swap alternators tommorow with another set of plugs. If that does not fix the problem, a COP will be on its way, and if that doesnt fix it the car will be crushed because this is getting old!!!!!
Old Nov 2, 2008 | 10:00 PM
DG Motors's Avatar
Other than Dan's fuel pump causing a voltage problem and getting his voltage back in the 12's, that was the only answer i have gotten from a high hp evo in terms of battery voltage.
Can anyone else give me their Battery Voltages during a pull?
Old Nov 3, 2008 | 08:23 AM
DG Motors's Avatar
anyone else???
Old Nov 26, 2019 | 02:01 AM
dillons13's Avatar
Originally Posted by DG Motors
anyone else???
hey
Did u find the issue
Old Nov 26, 2019 | 11:27 AM
WRC-LVR's Avatar
Originally Posted by dillons13
hey
Total necrobump 11 year old thread
Old Nov 30, 2019 | 08:26 AM
Justin Keith's Avatar
i would check your grounds in the charging system, recently had the same issue. moved the ground by the battery started seeing 14+ volts. my car makes 600whp.
jaredh
Dec 5, 2013 11:48 PM
JDM EVO 6
Feb 10, 2012 08:10 PM
asianfury01
Jun 1, 2011 05:16 AM
omniprobe
AEM EMS
Oct 29, 2008 02:04 PM
Johnboy1065
Jan 5, 2008 05:03 PM
