Ku Engineering Intake Mani, Does It Works?
Old Nov 2, 2008 | 08:36 PM
shangai's Avatar
I bought these part.. just installed it and i had to lean out the car cause the afr was to rich! i was making some math. if it get reachier, that means it has less air flow.. right? so does any one has try it? will it work? i already touch the 400awhp without it and stock turbo.. did i lost my time installing it??
Old Nov 2, 2008 | 08:56 PM
Ted B's Avatar
The length of the runners of this manifold appear to be too short. That much I can tell from the photo.
Old Nov 2, 2008 | 09:01 PM
nitroboy158's Avatar
I bought one for my stroker project and wish I hadn't!! Had to spend quite a bit of time port matching. Overall build quality is s#$t as well. I havn't fitted it yet and might sell it.
Old Nov 2, 2008 | 09:08 PM
konstantinosIX's Avatar
Sorry to tell you about... but this mani is a piece of **** !!!
Old Nov 2, 2008 | 09:09 PM
shangai's Avatar
just to let you know. you need to:
change uicp cause the inatke is lower there for small battery or trunk kit!!
change one of the heater hoses
extend the vac line to the brake pump
extend the vac line from the tank
it mached my head gasket!! so no porting!!
so is a lot of time and head involved on it..
SO DID I LOST MY TIME???
Old Nov 2, 2008 | 09:10 PM
shangai's Avatar
did you try it on a car??
Old Nov 2, 2008 | 10:57 PM
Yes,already two evo's.
Old Nov 3, 2008 | 01:26 AM
bsh's Avatar
bsh
I did a dynotest on stock intake vs ku engineering. (Evo 2):
http://www.lancerregister.com/showthread.php?t=163795
Old Nov 3, 2008 | 05:02 AM
JC evo1's Avatar
i think they may have revised the design recently as the runners in that pic appear to be nearly double the length of a KU manifold i held in my own hands. Maybe its just the pic..
Old Nov 3, 2008 | 05:11 AM
Ted B's Avatar
You may be right. Confusing, innit?
Anyway, the log posted on Lancerregister shows a power decrease until 6500rpm. If 'Ku' just brushed up his dimensions somewhat, he may have something.
Old Nov 3, 2008 | 06:54 AM
shangai's Avatar
WOW and you have a big turbo.. i only have a stock one on my car.. and i dont push the engine farder than 7,500 rpm.. so maybe i lost my time..
Old Nov 3, 2008 | 09:21 AM
ONRAILS's Avatar
shangai, add a big turbo
Old Nov 3, 2008 | 12:05 PM
shangai's Avatar
i love my stock one.. i already touch 400awhp with it at pump gas.. so im looking for a few more power to step up to a red or green turbo.. but im looking to get to the limits with my stock one..
Old Nov 4, 2008 | 09:02 AM
shangai's Avatar
bump
Old Nov 5, 2008 | 08:48 PM
shangai's Avatar
got the idle working!!! now lets see if it gains some hp!
