Evo VIII stall and drops rpm, my evo is one turtle!
Old Nov 3, 2008 | 06:38 PM
Oettinger's Avatar
I need much help! four months with this problem, I'm desperate. Three mechanics view my car (two mitsubishi-shops and one friend)... with no solution . I read two months this forum.
The problems is mi car stall in ramps or drops under 400rpm when drive and push the clutch pedal.
My turbo no up to "0" fast when push accel pedal in idle, only up to -250mg. In the red-line in idle up to "0" is veeey slow. One push rapid only up to -250mg, no charge to "0" and other evo's of my friends is very faaast to "0", my evo no.
HP with 23psi and afr 11.2 and 93ron is 4300rpm/323hp in the engine, is veeeeey low power. With G-Tech, G force power in 17.5psi is 0.34g, and 23psi is 0.39g.
I change "two" IAC, clean thee times throttle body , I see compressions in engine arround 160psi, change plugs by BR8IX 5044 and no view any leak...
Sorry my english, i'm spanish boy. I need any solution please! reading this post.
VERY THANKS FOR ALL!
Old Nov 3, 2008 | 06:41 PM
IEXCELR8's Avatar
Vacuum leak, boost leak.Dirty MAS.
Old Nov 3, 2008 | 06:53 PM
Oettinger's Avatar
I clean the MAS & used the new mas of my friend of his evo ix in my evo viii.
I change my old BOV MR for other new MR BOV.
My mods ir new MR BOV, filter ralliat in the box-air and exhaust 2,5'' ralliart, Apexi AVCR, new plugs br8ix and walbro 255. All is in stock.
My boost is 18psi to 3200rpm and 23psi to 3650rpm in 4th gear.
Old Nov 3, 2008 | 06:59 PM
gsrboi80's Avatar
Join the club ever since my turbo kit and injector install I cant get my car to fall to a decent Idle clutching down from above 2k.
Im going stand alone. Cant figure the issue out. Ive tried so moany things
Old Nov 3, 2008 | 07:12 PM
EvoHung's Avatar
Really? Can you give me examples of these "moany" things that you have tried? J/k. Do you have any aftermarket pulleys? Like the crank pulley. Have you checked all of your sensors? Is your throttle body gasket leaking?
Old Nov 3, 2008 | 10:40 PM
heavens turbo's Avatar
you've got good compression. could be fuel pressure, spark, or a controller issue. any check engine lights or codes? has it been tuned? open air filter? mods list and more info needed. really, we are all just guessing if we can't see the car. no mitsu dealer in barcelona? good luck.
Old Nov 4, 2008 | 04:31 AM
Oettinger's Avatar
Dealers in barcelona very bad's, no solution for my car. My mods is in post #3. Other boy with this problem in this forum and no solution in your car, live with this problem.
https://www.evolutionm.net/forums/sh...ght=stall+ramp
In my car no sound of leaks. Not see any leak.
Old Nov 4, 2008 | 05:06 AM
gsrboi80's Avatar
Moany LOL. No aftermarket pulleys, no boost leaks (well slight TB seals already replaced once but this was there before),No CEL's.
-Set BISS (The correct way)
-Tried Scaling the MAS (Doesnt do anything)
-Played with tons of idle, ICVS, and idle timing settings
Im really at a loss
Stand Alone in my near future fo sho
Old Nov 4, 2008 | 05:59 AM
Oettinger's Avatar
My Biss is correct, with SAS in evoscan 2.5 is in 800rpm. Seals in the thorttle body is the problem?? No sounds leak in TB or others parts in my engine.
And avanced to *7 degrees in ecuflash 0-40Load in 0-1000rpm and continue de problem... is not the solution. Walbro 255 defective?
Old Nov 4, 2008 | 10:04 AM
Oettinger's Avatar
bump!
Old Nov 4, 2008 | 06:31 PM
Oettinger's Avatar
up!!
Old Nov 4, 2008 | 06:45 PM
gsrboi80's Avatar
Sure *** **** I fixed it in my car today
Check it out guys
https://www.evolutionm.net/forums/sh...hlight=maf+map
Works 100% for the idleing issue
Old Nov 4, 2008 | 07:11 PM
EvoHung's Avatar
Nice. I'm glad for you man.
Old Nov 6, 2008 | 02:37 AM
Oettinger's Avatar
Check it out guys
My car no use MAP is with MAF is European model - 96530006 rom ...
Old Nov 6, 2008 | 05:13 AM
gsrboi80's Avatar
No no my car has a MAF too. We have a map sensor (look on your IM to the left of the valve cover) From what Ive read USDM will only see some rediculously small boost amount.
Thats why most Swap the out for the JDM 3 bar to log boost.
evoready on here can probably port the patch over to your ROM. If I knew how I would help you out
I am stupid when it comes to that stuff
