Street or puck clutch for my set up?
Just looking for advice if I should be going for a puck or street disk. End goal for the car is an fp green 400 whp range. Autocross/lapping day use, street use, not much drag racing.
Current clutch is an ACT street and it's toast.
^+1 on the street with a light weight flywheel. pucks hold like h*ll but annoying to drive dd esp if your not going to be launching. check out fidanza, i have there 9.5 lb flywheel and love it.
See the review of the Fidanza 3.2 on the Evom home page... judge for yourself. I loved the Clutch Masters full face Kevlar offering too when I had it. Personally, I like the longevity of Kevlar for daily drivers. If you are more of a road racer/auto-x person, it might be the last clutch you buy for a very long time.
Im running the act hdss pressure plate with a un-sprung 6puck disk and a act prolite flywheel and it great so far. Only have a few hundred miles on it but I haven't had a issue with it at all. Gets a tiny bit of chatter when taking off slow or up hills or something but not bad at all and you can drive around it.
Puck clutches not enjoyable? They are fine when chosen right.
https://www.evolutionm.net/forums/sh...d.php?t=366681
Mine is completely fine. Like I said a VERY small amount of chatter on hills or if I let it out really slow but it's so small that passengers can't even notice it. Just feels like a few pebbles in the road or something. I'm sure with a heavier flywheel it would be even better. Plus with the hdss pressure plate the tension isn't really bad on the pedal either.
