Can a combustion chamber be welded?
Old Nov 6, 2008 | 07:11 PM
Stevo8spec's Avatar
So I snapped a timing belt and couple valves hit the pistons and snapped the valves. It created a few pretty big dings, or more like dents in the combustion chambers on the head. I'm wondering if that's fixable or not? Is it possible to fill in the dents and then smooth it out? Or would that not hold up? If not it's no big deal since I have another head, I'm just wondering if I should toss it or not.
Old Nov 6, 2008 | 07:19 PM
Magnumpsi's Avatar
No new parts time.
Mitch
Old Nov 6, 2008 | 07:24 PM
Dan@DrivenInnovations's Avatar
steve
i was told by headgames not to long ago that depending ow bad it is it can be fixed. i sent a picture to dave and it had a nice chip off of where the spark plug comes through the head. he said he can fix it. i dont see why not in your case either. but dont hold me to it. call them
Old Nov 6, 2008 | 07:25 PM
takeshi999's Avatar
i'm sure you can weld it and smooth it out but then u would have to make sure all the chambers are the same volume..seems like alot of work just to save a few bucks...
Old Nov 6, 2008 | 08:17 PM
Stevo8spec's Avatar
Well it's a ported head, and although I can just port another one I have a lot of time invested into this one so it's not just a couple bucks. Making sure the volume is the same isn't a big deal at all really, I'm just concerned about if it will hold up. I'll give headgames a ring, they are great guys over there and do awesome work so I have no problems sending them my business if it's fixable.. Thanks for the help guys, much appreciated.
Old Nov 6, 2008 | 08:27 PM
1320awd's Avatar
where is headgames located and do they have a website?
Old Nov 6, 2008 | 11:06 PM
sprx19's Avatar
Can be fixed for sure, but the catch is it has to be done by a very skilled machinist. I work with a guy who does stuff like this. (I'm a tool and die maker) I have even seen this guy weld up pistons and machine them back in to spec and then have them last in drag racing. He races an 8 sec mopar. You are just at the mercy of the machinst in a case like this so if you try to fix it be sure you know the reputation of the machine shop.
I work in a world were anything can fixed, but at what cost or trouble?
Old Nov 7, 2008 | 12:33 AM
Aby@MIL.SPEC's Avatar
yes, you can have a head welded up / repaired.
take it to a decent welder. we used to have old nissan heads welded up. you could use a sharpie & he would weld right up to it & the sharpie didnt vanish!
the heads historicaly cracked in a certain area, after they cracked, he welded them, then they would last! Crazy.
depending on where the combustion chamber needs repair, you may want to have the seats replaced in that comb. chmbr.
Old Nov 7, 2008 | 12:36 AM
Billy@EnglishRacing's Avatar
yes it can if the damage is not bad
Old Nov 7, 2008 | 09:48 AM
28rRs's Avatar
yes, my head is welded
boostx
Dec 22, 2015 03:25 AM
quadrophine
Sep 2, 2012 10:39 AM
Insanity Evo
14
Mar 10, 2010 03:13 PM
deadbeatrec
Feb 16, 2008 05:48 AM
rhyzin
Lancer Aftermarket Forced Induction Tech
19
May 29, 2005 04:18 AM
