Checking "service engine soon" light.
Old Nov 11, 2008 | 11:37 PM
worksevo89's Avatar
Registered User
Question Checking "service engine soon" light.
So my check engine light came on today randomly. I actually haven't driven my car hard at all today so it was very odd. I was wondering if there was some way to check the code using EvoScan, ECUflash, or using some other method. I dont have a obdII reader so I hope I dont need one. thanks in advance.
Drew
Old Nov 12, 2008 | 12:10 AM
worksevo89's Avatar
Registered User
please!
Old Nov 12, 2008 | 12:15 AM
Massimo Power's Avatar
You have an HFC .... its most likely that
Old Nov 12, 2008 | 01:36 AM
dsmfan95's Avatar
You should be able to check CELs with EvoScan. I bought a cheap OBD2 scanner to check codes so I wouldnt have to hook the laptop everytime.
Old Nov 12, 2008 | 09:20 AM
booster9's Avatar
autozone checks codes for free with an OBD scanner. supprisingly no one knows that..
Old Nov 12, 2008 | 09:22 AM
Actually.. they stopped checking codes... i forgot why.. now they just want you to buy their ish
Old Nov 12, 2008 | 01:52 PM
worksevo89's Avatar
Registered User
I've had the HFC on for almost 2k miles, would really happen? What's the suggested remedy?
How do I use evoscan to check?
Old Nov 12, 2008 | 02:19 PM
worksevo89's Avatar
Registered User
Isn't there a trick with a spark plug spacer or something?
Old Nov 12, 2008 | 03:23 PM
Jay644's Avatar
Is it the "Service Engine Soon" light OR is it the check engine light? You seem to be referring to both and they serve two different purposes?
Old Nov 12, 2008 | 03:38 PM
worksevo89's Avatar
Registered User
Sorry its the "Service Engine Soon" Light.
Old Nov 12, 2008 | 03:43 PM
Jay644's Avatar
Check your manual or search on here. There's a way to reset it. All it means is that you hit a maintence interval that has been predetermined by the ECU based on your mileage. There's nothing wrong with your car.
Old Nov 13, 2008 | 08:12 AM
LuisIX's Avatar
i thought on the evo its the same light
Old Nov 13, 2008 | 08:23 AM
travman's Avatar
Go here:
http://www.aktivematrix.com/forum/dl...gory&cat_id=13
Create a username and password, and download the scantech file - its an OBD scanner that works with the tactrix cable and laptop.
Old Nov 13, 2008 | 01:58 PM
worksevo89's Avatar
Registered User
Thats what I thought.
Good news is that I disconnected my battery and reconnected to clean the light, so that seems to have worked.
We'll see how long it lasts.
Old Nov 13, 2008 | 02:02 PM
evane's Avatar
get a tactrix cable and laptop and download OBD Scanner from aktivematrix like travman said...thats what i use i can read my ses codes and clear them myself..
