Evo 8 16g Bolt up to 1st Gen Eclipse?
Old Nov 12, 2008 | 12:40 PM
Red_Evolution's Avatar
I guess you can see my question from the title... im trying to sell my buddy my stock 16g turbo off my evo 8.. and he has a few questions about whether or not its a direct bolt on...
and if its not a direct bolt on... what is needed to make this upgrade??
Old Nov 12, 2008 | 12:44 PM
evane's Avatar
not a direct bolt on....the turbos are flipped around...he would have to make a custom downpipe, custom intercooler piping, oil lines and water lines.
Old Nov 12, 2008 | 12:46 PM
what about the exhaust manifold ? would the 16g hotside bolt to the stock 1g mani?
Old Nov 12, 2008 | 12:49 PM
4g63smokinall4s's Avatar
it should there both T3 flanged
Old Nov 12, 2008 | 05:30 PM
Steve93Talon's Avatar
DSMs use a single scroll, round entry. EVOs use a twin scroll, asymmetrical entry. Neither of which is remotely close to a T3 flange.
As for bolting an EVO turbo to a DSM, it's been done a couple different ways. One way is to use an EVO manifold, which bolts right to the DSM head. Unfortunately, the turbo will hit the block and requires a 1"+ spacer and longer manifold studs. You also have to relocate the alternator to the rear of the block where the AC compressor is, and possibly eliminate power steering.
http://www.dentsport.com/gallery/v/d.../fittingTurbo/
The other option is to flip it so the compressor faces the pass. side and have a custom manifold made. This would be far from cost effective since a divided, one-off tubular manifold would be approaching $1k. The much cheaper, simpler solution is to just use the EVO3 16g, which is a direct bolt-on makes just as much power, and spools lightning fast.
Old Nov 12, 2008 | 09:37 PM
scheides's Avatar
EvoM Moderator
LOTS of JB WELD!
....seriously though, no.
Old Nov 13, 2008 | 03:58 AM
1NastyMR's Avatar
probably wont just get a dsm turbo from forcedperformance
nsheasley
Jun 3, 2015 08:44 AM
dspucches
Lancer Tranny/Drivetrain Tech
Oct 29, 2011 12:36 PM
Gusl
For Sale - Part Outs
Apr 6, 2011 05:23 PM
*02Lancer*
Lancer Engine Tech
Sep 28, 2009 08:33 PM
Ludikraut
11
Feb 27, 2008 05:30 PM
