BR Deluxe--> Evo 9 turbo solution?
Old Feb 17, 2009 | 10:23 AM
jjm4life's Avatar
Originally Posted by TURBevO8
The old version has an elbow (half of the licp actually) welded directly to the end tank on the PS. The newer version connects to the end tank with a coupler. So you can run a VIII or a IX licp and it just connects via this coupler.
thats the one i have. the older version. used the licp it came wiht from years ago, and it matched up with my evo9 outlet pipe.
OP hope thats the answer you were looking for.
Old Feb 17, 2009 | 10:37 AM
prostcj's Avatar
I'm talking about the version with the pipe built in. BR doesn't have a solution. I've called them.
Old Feb 17, 2009 | 10:38 AM
jjm4life's Avatar
thats the version i have.. with the pipe built in.. and a very short licp. its like just an elbow. matches right up to the evo9 outlet pipe.
Old Feb 17, 2009 | 11:31 AM
prostcj's Avatar
Interesting. Maybe worth buying the EVO 9 J-Pipe.
Old Feb 17, 2009 | 11:35 AM
jjm4life's Avatar
if you want it to fit, yes it would be worth buying.
Old Feb 17, 2009 | 11:45 AM
TeStUdO's Avatar
I run the old version of the intercooler with an FP Green. I run the IX j-pipe as well. It's a tight fit (i.e. the coupler is stretched a little) but it works.
Old Feb 17, 2009 | 01:06 PM
evofool's Avatar
i cut mine in the middle roughly and put a couple of t clamps on it, working pretty well right now
Old Feb 17, 2009 | 03:05 PM
evo@24psi's Avatar
Their is NO solution unless you have a custom one made. I had the same problem you are having last year. I called Buschur they told me either $300+ shipping to modify it or buy a new FMIC. Since they were so nice about it i did buy a new FMIC..........From ETS!!! Never looked back.
Old Feb 17, 2009 | 03:58 PM
prostcj's Avatar
I was also suprised when they basically said I was SOL. I would of thought they could of designed a pipe to fit the 9 turbos. Definitely soured me a little to BR.
Old Feb 17, 2009 | 05:13 PM
grillpt's Avatar
This is what the Old BR Deluxe looks like.
I have this sitting in my front room waiting to go on in the spring. The wife loves looking at it everyday...
You can find good deals on these things, so what if you got to spend a few bucks to make it work.
Old Feb 17, 2009 | 07:29 PM
evo@24psi's Avatar
Meaning almost every part on my car Was Buschur, it soured me also man.
Yeah i think i sold mine for $300.
Old Feb 17, 2009 | 08:57 PM
scheides's Avatar
EvoM Moderator
I just made my own pipe to connect to the stock IX outlet pipe. I used some cheap IC piping I had leftover from something or another:
I recommend welding vs jbweld though for the beads
Old Feb 18, 2009 | 08:45 AM
prostcj's Avatar
I'm going to try cutting the one I have and using a couple couplers. Bending it didn't work.
Old Feb 18, 2009 | 09:07 AM
TURBevO8's Avatar
Hmmm...That's interesting. I asked Jarod at BR about this a few months ago and he said they wouldn't line up. If this is truly the case that would be nice because you could just buy the IX install kit and be done with it.
Let us know if you do this and it works for you!
Old Feb 18, 2009 | 10:49 AM
evo@24psi's Avatar
I had 8 and a 9 J-Pipes and niether one would fit. There too short. Look at Grillpt pics and you can see it had an extension welded on.
