Very Confused Evo Caught On Fire!
Old Nov 17, 2008 | 01:01 PM
billy_06EVOIX's Avatar
Dang sorry to hear about that Hope you find out what the cause was.
Old Nov 17, 2008 | 01:05 PM
Malik_EvoIX's Avatar
vandalism from an STI owner?
Old Nov 17, 2008 | 01:26 PM
chargespeedMR's Avatar
Originally Posted by RoadSpike
Can you post some pictures of the engine bay?
You engine bay looks oddly smoke free for something that should be an oil or gas fire. Also the hood under and top side really looking for clues to where it started like burned residue on the exhaust manifold
Yes I am going to post more pics up now. Also the car was cleaned up A LOT! it was coverd with black smoke residue before.
Theres no way! Evo's will always own STI's
Old Nov 17, 2008 | 01:30 PM
Heres some more close up pics hopefully this helps.
If you look at the first pic, since those wires were so close to the exhaust manifold, I believe thats what may have cause the fire. But I'm not sure. I just want some other peoples thoughts on what they think.
Evoryder's Avatar
ouch
Old Nov 17, 2008 | 01:34 PM
Bimmubishi's Avatar
Check the wiring on all of the aftermarket parts. It looks like you have an MW spark box. Check that. It's a great product but could have been installed wrong. Any factory fault would be fuse protected so this is likely to be something else.
Old Nov 17, 2008 | 01:44 PM
JYoungEVO's Avatar
Registered User
sounds crazy man wish i could help good luck findin the problem
Old Nov 17, 2008 | 02:01 PM
RoadSpike's Avatar
I find it highly unlikely looking at these pictures that the source of the fire was caused by the electrical system. Note that none of the visible wires have burned through their insulation. Secondly if if it was a short the wire would have cooked evenly across the entire section melting off the insulator and started smoking badly then catch fire.
This fire looks to be fueled by something like an oil line maybe hooked to the turbo? Just a guess at this point would have been nice to see the car in person after the initial aftermath.
Old Nov 17, 2008 | 02:08 PM
dsmbruno's Avatar
so the car caught on fire while the guy had the hose out to wash your car?
water > fire
Old Nov 17, 2008 | 02:29 PM
water > fire
Well the car was about to get washed, my guess is that they had it outside idling and was grabbing some car wash supplies from inside and when they came outside they saw fire so they put it out immediately.
Old Nov 17, 2008 | 02:43 PM
dsmbruno's Avatar
^^^ its good they are hooking u up. time for a c/f front end
Old Nov 17, 2008 | 02:47 PM
evoixmr1818's Avatar
well at least the car didnt burn to the ground
Old Nov 17, 2008 | 03:37 PM
Yea I mean its good that nobody is hurt, its good that the car is not completely destroyed, I know this sucks. But does anybody else have any ideas as to how this may have happened!?!?!
Old Nov 17, 2008 | 03:49 PM
itzcharlez's Avatar
maybe the body shops ****ing with you so they make more money.
Old Nov 17, 2008 | 03:51 PM
fasterthanrays's Avatar
I think your friend hates you.
