Just finish installing the Perrin FMIC and Nisei LICP (Pics Inside)!
I just finish installing the Nisei Aluminum LICP and the Perrin FMIC. Installation was not too bad but took me a while to complete since I was trying to make it look as OEM as possible.
Here is a picture of the unit. It measures 35” from end to end; core is 25” wide by 3.5” thick. Pretty good size!
This is the intercooler input. Casting size is a little on the big size. I guess bigger than the sheet metal fabricated tank units.
Nothing a good drill and dremel tool with carbide bids can't fix.
I just ported about ½ inch on the input and output to make things smother. I did not want to weaken the area where the T Bolts puts pressure.
The unit was installed along with a Nisei Aluminum LICP. Fitment and quality on the Nisei was A+.
I really like the idea to have a bracket holding the pipe.
Here is the unit from the front. I decided to paint the top part and bracket black so you cannot see the aluminum intercooler core when looking from the bumper openings. Just like the OEM unit.
Here is the unit looking from the top. It barely clears the crash bars at the end of the core. I actually trim a little the crash bar at the core to tank weld area since it was touching the intercooler after tightening the bolts. I just trim a little to have a gap in there. Note the flat black painting on top of the core.
I cut and painted the edges of the bumper holding nut to make sure it has more than enough area to clear the tanks. I had to re-orient the T bolts to the back to make the bumper fit (No photo in the new orientation).
Here is a photo I took after finishing. It was getting dark so it is kind of blurry. All the installation was done at night that’s why the photos are not very clear. I will take some more photos at daylight to see how it looks. The red integra GS-R on the back is my spare car and for now the daily drive. Fun to drive and not too thirsty with gas.
New Pictures taken this morning.
Now I have to tune my ECU Boost Control because for some reason I am boosting about 2 PSI more than before.
Time to retune again!!
The overboost is not too bad. It is a little bit higher at night. But I know the error correction on the ECU based boost control is kicking in and getting boost back to 22 PSI. I just have a small overshoot when I get on it.
I have setup the ECU based Boost Control with the GM 3 Port and JDM Map sensor so error correction brings everything back to 22 PSI where it should be. I will still fine tune it so it stays where it should be without having to use boost error correction too much and avoid any spikes.
