Who is running 4g64 motors? Chime in!
Old Jul 4, 2009 | 02:10 PM
  #31
dsevo's Avatar
Originally Posted by gotrnet
just thought i would update, last dyno, my eclipse spyder, 4g64, 1600cc injectors, made 590hp 578 tq, with the gt35r.
Have you had any HG issues. What boost? What HG? What studs? etc. Thanks
Old Jul 4, 2009 | 04:50 PM
  #32
gotrnet's Avatar
None what so ever. i do have an o-ringed block and am using a cometic HG. it was running 34.5 psi on that run, but i have since got it down to 29 but keeping the same hp by messing with the timing a little. they are def arp head studs but i cant remember if they are 1g or 2g. Was going to upgrade to the A1 studs if i ever have to take the head off. i also only rev to 7500 rpm. it makes peak power about 5500 and holds all the way to 7500.
Old Aug 18, 2010 | 04:18 PM
  #33
gotrnet's Avatar
i realize this thread has been dead for a while but since it is one of the few places i have posted info about my 4g64 spyder thought i would give an update. dynod last weekend and made 661hp 651 tq!
Old Aug 18, 2010 | 04:32 PM
  #34
Acree's Avatar
That's awesome. Nice numbers!
-Acree
Old Aug 18, 2010 | 07:00 PM
  #35
diablo2184's Avatar
More info, specs, etc!
Old Aug 18, 2010 | 07:06 PM
  #36
05ah8james's Avatar
I'm running a buschur 2.1L 4g64
Old Aug 18, 2010 | 07:21 PM
  #37
gotrnet's Avatar
i am running a 4g64, although it is in a 99 spyder. it is the orginal motor in the car when i purchased it. it was converted from sohc to dohc and from fwd to awd. it is running a 35r with 1600cc injectors, Fuellab single pump, completely stock 1g head with bc272 cams, wiesco pistons with eagle rods at 9.0 cr. it makes 661hp 651 tq at 36psi. it hits full boost at about 3700rpms and crosses the 500hp mark at 4500rpms and crosses the 600hp mark at 5k and holds it to redline 7500rpm.
Old Aug 18, 2010 | 09:00 PM
  #38
doyle4281's Avatar
starting mine soon.....should be fun
Old Aug 19, 2010 | 08:27 AM
  #39
JohnBradley's Avatar
Nice. 2.4s are really nice street motors for sure. Good torque and great power at relatively low boost when the combo is all there (cams, headwork, turbo).
Old Aug 19, 2010 | 08:32 AM
  #40
buchnerj's Avatar
I am running one. A BR 2.1L 4G64. Running great, good power. Over 510/510 for sure, going to the dyno to get the updated numbers soon.
Old Aug 19, 2010 | 09:02 AM
  #41
RockmanX's Avatar
thats what im waiting for you to post a dynograph finally according to you. your running close to what liqquid was doing on stock motor.
BTW i am running a built std 2.4 (4g64) as well have not put any miles on it personally(shop has 300miles on it) as im still buying more parts and getting it tuned
Old Aug 19, 2010 | 11:45 AM
  #42
PAdutch's Avatar
Are you driving this set-up on the street? How big of a pain is it in stop and go traffic. I hear people say how the 2.4 is a great street engine because of the torque but you only really need the tourqe when your pulling out.
I think it would be awesome to have a 2.1l the revs to the moon on the street.
Old Aug 19, 2010 | 12:01 PM
  #43
Murf's Avatar
SBR is doing a 2.4 for me right now. I had them do the upgraded (lighter) rods so it cost a little more. I'm getting everything in a kit from them, to include came gears, water pump adapt, timing belt and head gasket.
Old Aug 19, 2010 | 01:09 PM
  #44
Earthen's Avatar
I am also running 2.4, see my thread https://www.evolutionm.net/forums/ev...ml#post8597894
Old Aug 19, 2010 | 01:23 PM
  #45
Earthen's Avatar
Haha, your still working on it? I wonder which of us will be done first...
