Who is running 4g64 motors? Chime in!
Old Aug 19, 2010 | 01:25 PM
  #46
Earthen's Avatar
Originally Posted by crcain
The negatives I've had with the 64 block are:
- my AMS header actually touches the heat shield under my bonnet.. the number 1, and 2 primaries... and they are a bit scratched from it. has not been a problem except it scratched my pretty header
- my AMS turbo support bracket needed to be drilled and fab'd a bit to work
- we had to fab my alternator bracket a bit
- had to lengthen oil return line as it was a bit taught
And then as has been mentioned already, if you go beyond standard bore, gasket choices are not great. Stick to standard bore and you can use HKS.
Also you need a modified water pump which I got mine from Magnus.
You need to degree the cams and use adjustable cam gears as the factory timing marks are a no go since you are running a higher deck.
Otherwise it's a good choice but there are little issues. I think I've ended up with a very responsive setup given the power output of my car.
These are not problems...what do you expect when you put a different block in a car it wasn't designed for initially? All the things listed here are nothing really.
Old Aug 19, 2010 | 01:44 PM
  #47
RockmanX's Avatar
Originally Posted by PAdutch
Are you driving this set-up on the street? How big of a pain is it in stop and go traffic. I hear people say how the 2.4 is a great street engine because of the torque but you only really need the tourqe when your pulling out.
I think it would be awesome to have a 2.1l the revs to the moon on the street.
i dont get this question lol all the motors will start and stop and go the same. LOL a built 4g64 does not start and move any different then a 4g63. I can understand if you talking about preformace but regular day to day you will be hard pressed to find a difference in basica driving from 2.0-2.4
Old Aug 19, 2010 | 02:02 PM
  #48
RockmanX's Avatar
Originally Posted by Earthen
Haha, your still working on it? I wonder which of us will be done first...
There are MAJOR differences in my build and 99 perfect of others lol I got the whole show theme thrown in there so takes time to make custom parts and thinking out the way i want things layed out. NOW my evo is running and drivable. It has a dumbed down mild tune as im awaiting my new exedy twin and parts carlos has powdercoated for the blue bomber
Old Aug 19, 2010 | 02:15 PM
  #49
Earthen's Avatar
LOL, nice...lucky you your car is driveable, mine still isn't. My buddy is also doing the same on his build, EVERYTHING is powdercoated and perfect for looks etc. I just removed everything that wasnt needed, so I didnt have to deal with that. I dont show under my hood anyways...lol.
Old Aug 19, 2010 | 06:48 PM
  #50
RockmanX's Avatar
show and go yes please
KOOLER
Jun 19, 2017 07:41 AM
babaz7
10
Jun 18, 2017 12:37 PM
joeymia
54
May 7, 2017 07:47 AM
foxbat
16
Aug 4, 2016 07:45 PM
foxbat
Dec 8, 2015 01:11 AM
