2.1L dipstick 4g63 or 4g64?
Old Jun 12, 2017 | 10:10 AM
babaz7's Avatar
i have a 2.1L engine, should i use the 4g63 dipstick that i already have or get a 4g64 dipstick?
or are they the same?
Old Jun 12, 2017 | 11:47 AM
ExViTermini's Avatar
63 stick and bend the holddown to fit.
Old Jun 12, 2017 | 12:00 PM
mines5's Avatar
Z..
Doesnt matter... 4g63 should be fine.
Old Jun 12, 2017 | 05:27 PM
babaz7's Avatar
Originally Posted by mines5
Z..
should I fill the oil at the same level? I fill it till the second tab on the dipstick...the 4g64 block is 6mm taller, should it make any diffrence?
Old Jun 12, 2017 | 08:45 PM
mines5's Avatar
Same level fill up is fine. Just make sure to check oil level every time you take her out. Which oil are you using?
Old Jun 12, 2017 | 09:00 PM
the 6mm taller is the deck height, ie from crank CL to head surface.
Old Jun 12, 2017 | 09:58 PM
babaz7's Avatar
its a brand new build, im using the royal purple break in oil for the first 300 miles, then plan on using royal purple 10w-40 synthetic oil.
Old Jun 12, 2017 | 10:23 PM
mines5's Avatar
Good choice. Using the same. Did countless tuning sessions, street driving and drag. Never had a complain. Amsoil is the 2nd choice.
Old Jun 16, 2017 | 06:03 PM
EvoEarl05's Avatar
i also have have a 2.1 build and use a 63 dipstick and works fine
Old Jun 18, 2017 | 07:54 AM
KOOLER's Avatar
what about redline oil? i run 15w50 r/l now but i didn't had evo for 3 years, so might be some better choices now
Old Jun 18, 2017 | 12:37 PM
mines5's Avatar
Didn't had a chance to use redline engine oil. Have used it in transmission. Motul 300v is another good choice. Couple of friends are using liquiy moly 10w40.
CeliOnce
19
Jun 25, 2015 07:48 AM
mrboost05
Mar 6, 2013 09:58 AM
karwh0re89
Dec 9, 2012 03:29 PM
Kemist
Mar 1, 2009 03:33 PM
hybrids14
Mar 19, 2007 01:06 PM
