Do I have the quickest/fastest stock ecu/mas EVO?
Chris, when we made our last passes on the Green, we went 10.61 at 131 mph. I always felt the car had a lot more mph and et still in it, but the lift shifting was making probably 3-4 mph difference. It never was run with full slicks, so I'm not too sure what the et could have been. The RED and White came out and we were already behind schedule in getting them tested, so we abandoned the Green and went straight to the RED and White testing. The Green was good, but your 10.41 at 135 owns us on the stock ecu and stock maf.
thanks Tom, I knew you and Tony pushed it hard and into the 10's but wasn't sure how far...that's very impressive for a much smaller turbo than mine, I bet that green had some incredible shaft speed!
p.s. I copied your format for the title text in my sig, hope you don't mind.
yep, I've had a bunch of customers go to the dyno and almost all of them got a few more ponies on the dyno, likely because I use a conservative weight for the driver and don't do any sae correction that would inflate the numbers.
First I'm going to finish the pump gas tune with the new HTA86 turbo and I might take it to the track like that IF I see a big enough improvement to warrant that (unlikely).
Then I'm going to get started on the c16 tuning, dial the AFR back in and start pushing the boost on up and see if I hit a barrier though the stock ecu/mas.
I reviewed the log later and had 1 count of knock so I feel like I might be able to add a little more boost or timing.thanks for the compliment, I can't wait to push it into the 9's on the stock ecu/mas I think that would blow some minds and rewrite the book on the stock ecu limitations.
p.s. I took the stock ecu/mas further than anyone else on 3si.org as well which is THE 3000gt VR-4/Stealth TT international site. People used to tell me you can't go 11's on the stock ecu. It did a best e.t. of 11.45 and best mph of 127 on 93 octane. Not bad for a 3800lb boat with me in it ~575awhp.
