OBD-II scanner
Old Nov 28, 2008 | 08:45 AM
btownsoccer22's Avatar
OBD-II scanner
Can anyone recommend me an OBD-II scanner for checking codes and what not. I have read up on some but the ones i have read seem to only read a limited number of codes. So i was just wondering if some of you evo guys with your own scan tools can tell me what your using and if you like it and if it reads all power train codes. Thanks
Old Nov 28, 2008 | 02:48 PM
Draven83's Avatar
the one for like 100 at autozone is good. thats the one i use
Old Nov 28, 2008 | 02:49 PM
CaliMR's Avatar
+1, my bro bought one for his boat with OBDII, and it works fine on my Evo and my DD
Old Nov 28, 2008 | 02:53 PM
ROGERV's Avatar
I bought this one at autozone $80 Works great .
http://www.etoolcart.com/actron-pock...us-cp9410.aspx
Old Nov 28, 2008 | 06:12 PM
EvoJoeIX's Avatar
autozone scans for free
i always just go there when i get some random code
Old Nov 28, 2008 | 06:41 PM
bao's Avatar
bao
sears code reader works ok too.
Old Nov 28, 2008 | 06:57 PM
DonHugo's Avatar
The difference is in how much you want to know. I bought a"pocket" OBD II code reader at autozone for $45. It only tells you what the code is, as in P0300. It also gives you a book to look up the code the reader gives you. Whereas the other more expensive reader, about $80-100, would tell you P0300 random engine misfire. Personally, I don't care that I have to look up what that code means, it saved me about $50.
Old Nov 28, 2008 | 06:59 PM
intravino's Avatar
Check out this OBD2 scanner.
It is pretty good except you need a laptop, desktop, palm or pocket pc to run it.
Old Nov 28, 2008 | 07:11 PM
jmelocik's Avatar
Whatever you decide to get I highly recommend getting one that shows freeze frame data and readiness codes and their status. Especially if you live in an emissions area. If not and you just want to keep clearing recurring codes then get a Creader off of Ebay. I have one that the local Snap-on guy sells the Innova 5100 I think is the model.
Josh
Old Nov 29, 2008 | 09:29 AM
Slo_crx1's Avatar
Scan Tech is what I use, free program to download from the AktiveMatrix forum and use in conjunction with the Tactrix cable. Shows me codes, freeze frame data, pending DTC's, the whole 9 yards.
Old Nov 29, 2008 | 09:33 AM
Josh
Can you give an example of a scanner that shows freeze frame, and readiness codes
Old Dec 1, 2008 | 09:12 AM
jmelocik's Avatar
Sorry been moving the last few day. Yes the high end Actron unit at Advanced auto parts is a good hand held unit, also as stated above the ScanTech software is excellent if you have a laptop and Tactrix.
Josh
Old Dec 1, 2008 | 06:55 PM
04AWDTURBOEVO's Avatar
I use this gauge & I like it very much.
The ScanGaugeII
3-in-one Automotive Computer ScanGauge 2 | Features | Photos | Support | How to Buy | Contact Us | X-Gauge | HOME Easy to Install
Connects In Seconds The cable is detachable at the ScanGauge II and can be connected on the back or side of the unit. Once connected to your vehicles OBDII port, the ScanGaugeII automatically negotiates communications with your cars computer - It's that easy!
Compact Size
Fits Almost Anywhere The compact size of the ScanGaugeII allows you to mount just about anywhere. it's so small, you can even slip it into your pocket and take it with you.
The dimensions of the ScanGaugeII are 4.8" wide by 1.5" high by 1.0" deep. The cord from the diagnostic connector to the control/display is 6' long and about 0.2" in diameter.
Read and Clear Trouble Codes
BUILT-IN SCAN TOOL
The ScanGuageII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
Learn more ››
DIGITAL GAUGES
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
Learn more ››
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
Learn more ››
View Photos
of the ScanGauge II
View a series of photo of the new ScanGaugeII
Photos ››
ScanGauge 2 | Features | Photos | Support Center | How to Buy | Contact Us | HOMEScanGaugeII - by Linear-Logic.
© Copyright 2004-2008. All rights reserved. _qacct="p-c3NyIscqiz7TE";quantserve();
Old Dec 1, 2008 | 07:03 PM
Here is a recent picture of the gauge on my car:
Old Dec 6, 2008 | 04:24 AM
Nelissen's Avatar
Scangauge II works great for me
Eric.
