Buschur Racing Mass Air pipe & Filter!?! The Good and the Bad?!?
Old Nov 28, 2008 | 05:56 PM
red03evo's Avatar
Originally Posted by Mike@AwdMotorsports
Yep you can buy the MAF pipe for 210.00 then the filter and adapter elsewhere for 40.00 and pay shipping and it comes to 260.00 just like the kit if you buy it from Buschur complete.. I dont really see much savings there..
agreed
Old Nov 28, 2008 | 07:03 PM
Thoe99's Avatar
Originally Posted by shoman21
...what is the purpose of the breather filter? and is it need? because i have the perrin full intake system and i didnt have to run that. j/w
So what's the answer to this?
Old Nov 28, 2008 | 07:47 PM
Mellon Racing's Avatar
The buschur intake pipe doesn't have provisions for that hose that normally runs from the valve cover to the intake. The reason for this is because you don't want that oily blowby mess going into the turbo and thus the FMIC where it will coat it and drastically reduce it's ability to cool the intake charge.
Old Nov 28, 2008 | 09:06 PM
FastAzzEvo's Avatar
why you getting rid of the perrin? I just bought it from my apexi and I really like it..
running a little more leaner though.
Old Nov 28, 2008 | 09:20 PM
PeteyTurbo's Avatar
I like the Dejon harpipe because it will also fit with the stock airbox..
Old Nov 29, 2008 | 07:46 AM
shoman21's Avatar
it's not bad but i don't like the silicone intake tube. i want to go to a hard pipe because i plan on going bigger turbo and more boost.
Old Nov 29, 2008 | 07:56 AM
Steve93Talon's Avatar
http://www.jmfabrications.com/catalo...roducts_id=117
Old Nov 29, 2008 | 08:36 AM
shoman21's Avatar
thanks for the info
Old Dec 2, 2008 | 08:11 AM
TheDream's Avatar
I tapped my intake as well and ran my stock hose back to the valve cover, I recommend doing this.
Old Feb 17, 2009 | 03:53 PM
kmcconn9's Avatar
Where are you guys getting the adapter to tap the intake pipe for the hose back to the valve cover??
Thanks
Old Feb 17, 2009 | 04:25 PM
justboosted02's Avatar
Thanks
home depot. its in the plumbing section
Old Feb 17, 2009 | 04:45 PM
kmcconn9's Avatar
Thanks, although I looked a while back and didnt see one. I will check again tommorow..
Old Feb 18, 2009 | 08:55 AM
why would you guys want that oily blowby going back into the intake? You know that coats the FMIC and hurts the efficiency right?
Old Feb 18, 2009 | 09:04 AM
TheDream's Avatar
When you're running a BFIC, I don't think you need to worry.
In all seriousness, it helped with some of the stalling issues I had previously. I basically tried to make it function like the stock tube. With a tune, I wouldn't think you would need to tap the intake, especially if its from Chris.
BTW Chris, my car is almost ready to go, just need to put the pump in and it will be up at Buschur's.
Old Feb 18, 2009 | 09:05 AM
gotcha and you're right, tuned you won't have stalling issues anymore good luck
EmeryatSTM
Feb 3, 2010 04:51 PM
MaxKanisha
39
Oct 2, 2007 03:56 PM
CarFanatic
16
Jun 16, 2006 11:04 AM
Evo#1
12
May 24, 2006 06:06 AM
pinoyesv6
Sep 3, 2002 08:43 AM
