Upper I/C piping
Old Nov 28, 2008 | 09:23 PM
VictoryEVO's Avatar
Upper I/C piping
I dont want to run the small battery kit on my car. Can anyone suggest an upper
pipe thats good for the stock battery set up or am I just screwed on my wishes?
I already have a used Burschur core and lower piping.
THX for your input
Old Nov 28, 2008 | 09:32 PM
merlin00069's Avatar
THX for your input
Check out the space you have to work with after the small battery conversion. It's outstanding. Id recommend it for the mod you want to do as well as making space for yourself for future projects.
Old Nov 28, 2008 | 09:44 PM
chaotichoax's Avatar
don't bother replacing the stock pipe just replace the couplers
you won't see any gains with a pipe in the same orientation
stock couplers expand under boost though so those should definitely be swapped out
Old Nov 29, 2008 | 03:38 AM
VRamirez2004's Avatar
Greddy, or dejon tool upper intercooler pipes fit the stock battery.
Old Nov 29, 2008 | 06:13 AM
i8yourSTi's Avatar
Obviously he doesn't want a small battery for a particular reason or else he wouldn't of made the post. The bad thing about small battery kits is if you let them drain out once you might as well just throw them out.
Check out the Injen pipe, ETS or GReddy like someone mentioned if you want to change the stock piping.
Old Nov 29, 2008 | 06:20 AM
Chemwarrior's Avatar
I have the ETS and love it. You can't go wrong with them.
Old Nov 29, 2008 | 08:32 AM
RyanEvo2006's Avatar
+1
Old Nov 29, 2008 | 10:43 AM
Kracka's Avatar
I'd go for ETS if I kept the stock battery.
Old Nov 29, 2008 | 10:52 AM
VictoryEVO's Avatar
THx guys you have been a big help!
Old Nov 29, 2008 | 10:53 AM
Evoryder's Avatar
Just put the battery in your trunk. It's not hard to do and is good for distributing weight. And you have a great amount of room in the front end to put whatever piping you want
Old Nov 29, 2008 | 11:55 AM
VictoryEVO's Avatar
Nice install!
ThX for the tip on ETS I love the looks of the gloss black pipe!
Greddy's not showing or much of nothing on their part on the site
Old Nov 29, 2008 | 01:47 PM
gottf257's Avatar
+1 or move the battery to the trunk if you still want a full size. couplers are a great mod though
Old Nov 29, 2008 | 02:43 PM
RockmanX's Avatar
[/URL][/IMG]
I would go with injen polished upper ic(does come in black). i just installed all this today. But there are many choices its your Evo.
Old Nov 29, 2008 | 08:04 PM
bao's Avatar
bao
ETS for me...
Old Nov 29, 2008 | 08:12 PM
Taiman's Avatar
ETS with stock or use the ETS or Nisei short route & use the honda battery (Group 51). For honda battery, you will need to fab a battery tray for that (I have seen several EVOs doing that and it looks great!). Good Luck!
