idle problem with evo
Old Nov 29, 2008 | 04:58 PM
Evoryder's Avatar
What rom Id are you using? This does seem to be mechanical.
Old Nov 29, 2008 | 04:59 PM
sharkm87's Avatar
008
Old Nov 29, 2008 | 05:03 PM
Evoryder's Avatar
I used to have idle issues with that rom. Switched to the 0015 and it made a difference in idle stability. I even changed my IACV but the rom switch was the main fix. I run meth and it tends to go through the valves.
Have you boost leak tested your car yet?
Old Nov 29, 2008 | 05:17 PM
sharkm87's Avatar
no boost leak test done yet...i will do that tomorrow
Old Nov 29, 2008 | 05:36 PM
Evoryder's Avatar
over and out. lol ...nothing else to trouble shoot. unless you want to check your coils and then do a compression test. But i doubt you have a kit.
I'd test the coils
Old Nov 29, 2008 | 05:44 PM
sharkm87's Avatar
and yes, i do have a compression tester..but it just dont make sense for htat to be it..i last done my test when i installed my plugs month ago..so i know tahts not it....i'll do the boost leak test
Old Nov 29, 2008 | 07:37 PM
Evoryder's Avatar
Nothing wrong with a compression test.
Old Nov 30, 2008 | 12:18 PM
cfdfireman1's Avatar
relearn idle
Originally Posted by sharkm87
yea but it didn't...that didn't work
how long did you let it idle after it was up to temp?
Old Nov 30, 2008 | 05:14 PM
sharkm87's Avatar
had it on for about 20 min...was idlin fine...soon as i shut her off and on, same issue.....willd o boost test tomorrow.
Old Dec 2, 2008 | 06:58 AM
sharkm87's Avatar
performed boost leak test...fixed all the minor leaks..and same issue still..car will turn on and die right after ulness gas is held down, it will never regain idle on its own....
Old Dec 2, 2008 | 07:44 AM
sharkm87's Avatar
when the car wants to, it will start up and idle fine, but as soon as you press the gas the idle will not regain itself, instead drops to 0 rpm..
if theres someone in jersey area with a maf, feel free to pm me to see if thas the problem.
Old Dec 2, 2008 | 08:16 AM
sharkm87's Avatar
well, i'm goin to obtain a maf and try that......
still open to other suggestions
Old Dec 2, 2008 | 05:47 PM
sharkm87's Avatar
bump for more ideas while the maf comes in...
i went out and turned car on just now, and it idled fine, i blip gas, and it didn't cut off....so idk wtf is goin on with this thing,...it happens when it wants to so i think its something electrical..but idk
Old Dec 4, 2008 | 09:09 AM
sharkm87's Avatar
bupm for help, received the maf today, and still same issue....could it be the front o2 sensor??? causing this
Old Dec 4, 2008 | 11:20 AM
sharkm87's Avatar
looks like its the iac...lookin to purchase one now
