Is 30psi on stock turbo 2 much???
Old Dec 11, 2008 | 11:26 AM
scheides's Avatar
EvoM Moderator
I ran 26psi peak for about a year, then upgraded to an IX turbo about a year ago. I've been running 29psi (peak) tapering to 24 at 7k (gm bcs ftw!) daily. Turbo is fine, more boost doesn't always mean more power, but it certainly doesn't hurt
Old Dec 11, 2008 | 11:34 AM
MuslimEvoFreak's Avatar
Originally Posted by Dsmhater
Hey do you mind listing your mods ? That is some serious horsepower on stock cams and stock turbo.
Congrats
+1!!! That power curve looks promising yet dangerous!
Also, anybody know of John Drew in the Chicagoland area? He is supposedly running 31psi on stock turbo running high 10's? This is what I have heard from a lot of DSM owners. Anyone care to chime in?
Old Dec 11, 2008 | 11:36 AM
Evo9Kid's Avatar
i did it for 30k miles and had no problem at all
Old Dec 11, 2008 | 11:57 AM
JohnBradley's Avatar
30psi on meth, racegas, or E85 is not uncommon on a stock turbo (I know someone that was running a 34psi spike ).
Most of the time this will work for longer than the motor lasts. Sometimes you get that turbo that doesnt, but I have seen an easy 30,000 at that level. I run this everyday on the stocker that is currently on my car and ran the Green that way for 36,000 miles before I took it off and its currently on another car doing eaxctly the same.
Old Dec 11, 2008 | 12:58 PM
RyuEvoIX's Avatar
Congrats
I'm no longer on stock cams. I have Cosworth m2'S
Old Dec 11, 2008 | 05:55 PM
nikkadanny's Avatar
i was running 30psi with meth for a couple months..it was fun =)
Old Dec 12, 2008 | 02:05 AM
1NastyMR's Avatar
I ran 30-33lbs so no 30 is fine aslong as you are on 110
Old Dec 12, 2008 | 03:57 AM
EvoChrisLee's Avatar
i have seen a lot of people running 30psi and didn't even know it when they get on the dyno the TQ is always crazy high
Old Dec 12, 2008 | 08:22 AM
URBANRCR's Avatar
30psi is fine i wouldn't go above that though of course this is with meth/alky or race gas thrown into the mix.
Old Dec 12, 2008 | 08:46 AM
Actually you can run a 30psi spike on pumpgas as long as the timing is good and the spike doesnt hold for an extended period of time. We had 3 cars at our last dyno day that the owners intentionally set up this way and then had us tune.
Old Dec 12, 2008 | 08:54 AM
Evoryder's Avatar
30psi for about 2yrs now used to hold 26[26.5 at redline. Since adding cams and wastegate, most I can hold is 25psi @ redline. Without meth and failsafes I wouldn't recommend. Once I change out my clutch discs and add headstuds I'll be going for 32psi till I save up for a red.
Hiboost
17
Jul 19, 2019 09:01 AM
Nadaevo
Feb 12, 2016 09:44 AM
selp
13
Dec 9, 2014 04:55 PM
joek84
Jul 13, 2010 01:09 PM
