Evo + Honda = boosty goodness
Old Nov 30, 2008 | 01:03 PM
whitey4d's Avatar
I have 3 freinds around my way locally taht are all running EVO 3 turbos and EVO 8 intercoolers with 440 DSM injectors. 1 is a b16 and the other 2 are d16z6s. 2 of them are in the 12s and arnt hatches.
Old Nov 30, 2008 | 01:05 PM
Evoryder's Avatar
Those are some sexy welds
Old Nov 30, 2008 | 01:53 PM
awdboostftw's Avatar
welds look great but 250whp on stock d15 rods? risky...
Old Nov 30, 2008 | 02:10 PM
4G63-KID's Avatar
This build looks like fun and who cares how dirty the engine bay is. If your car goes fast, it goes fast. That hypermilling s**t is crazy. 25 to 1 AFR? what kind of egt's are you seeing?
Old Nov 30, 2008 | 02:27 PM
nikkadanny's Avatar
pretty sick, how much for a mani for a bseries?
Old Nov 30, 2008 | 04:01 PM
Steve93Talon's Avatar
It's a D16. Plenty of people have pushed stock bottom ends alot harder than that reliably.
Old Nov 30, 2008 | 04:58 PM
Broxma's Avatar
We're going to try the same setup on a Miata at work. With a MegaSquirt we can run the stock Evo low Imp injectors so we are basically going to take the Evo turbo, mill a flange for it and an exhaust flange for the Miata and fab up a manifold. Rods again are the problem with the Miata. We already have the IC and pipes for the Miata since that's what we do so other than the mani and DP should be a bolt it.
/brox
Old Nov 30, 2008 | 10:29 PM
evoprime1's Avatar
NICE! looks sick!
i have an extra 8 turbo i dont need
shoot me an offer
Old Dec 1, 2008 | 01:34 AM
C6C6CH3vo's Avatar
Originally Posted by vince64
Tuned with some tricks I plan to run up to 25:1 AFR's light load cruising
Will that lean even support combustion, even on a quick burn honda engine? Typical engines will miss at around 16 afr
Old Dec 1, 2008 | 04:46 AM
Laxman's Avatar
For a "beginner" those welds are damn nice!
Old Dec 1, 2008 | 05:46 AM
evoWWrs's Avatar
very nice welds
Old Dec 1, 2008 | 05:53 AM
EVILutionVIII's Avatar
Veteran: Air Force
Nice welds
Old Dec 1, 2008 | 07:24 AM
nos51's Avatar
yea i was thinking the same thing,if my honda goes around 16.5-17.0 a/f is starts to buck a little,makes for crappy drivability.i usually run it around 14.5-15.0 a/f partial throttle and it gets about 25-28 mpg on 1200cc injectors.
Old Dec 1, 2008 | 04:33 PM
tunermt's Avatar
This is very true, I have tuned just a hand full of these v-tec E Honda engines and they will run LEAN!!!!! the engine will start to miss at around 24-26 to 1!!!!!! of course this is under cruising conditions. better MPG than a hybrid!
subi's, Nissan, mitsu I have tuned will all start to buck and miss around 15.5-17 to 1 (again cruising conditions)
Old Jan 6, 2009 | 10:38 PM
TRD11's Avatar
I have been trying to hypermilage a D15 3-stage VTEC motor, and my PLX wideband stops at 20:1. However, through interpolation in Hondata my highest AFRs are normally around 22-23:1. The car is still N/A though...
SEE YOU AT THE SINGLE CAM SHOWDOWN VINCE
