GT-A transmission oil change
Old Nov 30, 2008 | 06:59 AM
nads1978's Avatar
Hi, basically does anyone know where I can find an on-line guide showing how to do an oil change on the auto transmission, and which parts I'll require - such as filters, sump plug washers etc.
Done a search on here, on the web, on the UK site (where I'm from) but no luck as yet.
Also does anyone have a GT-A workshop manual - The auto box is not covered in the normal Evo workshop manual.
Regards.
Old Nov 30, 2008 | 09:11 AM
MitsuJDM's Avatar
Aren't there any Mitsubishi dealers in the UK? I would go there and ask if you can.
Old Nov 30, 2008 | 09:22 AM
nads1978's Avatar
Yes, but are unhelpful because it is an import. We did not get the GT-A in the UK, therefore no one in my local Mitsubishi dealership knows much about them.
Old Nov 30, 2008 | 09:46 AM
MR Turco's Avatar
is it a 5 speed or 6 speed?
Old Nov 30, 2008 | 09:59 AM
alan678's Avatar
Its a GT-A.....Automatic 5-speed Evo 7...
Old Nov 30, 2008 | 10:00 AM
nads1978's Avatar
5 speed, is there a 6?
Old Dec 1, 2008 | 01:02 PM
Davo's Avatar
basically your typical auto fluid change
u can use the fluid exchange machine or a diy method i usually use
it takes approx 7-8qts of Diamond SpIII oil
drain tranny on the side bolt, usually a hex.
when finished, close back.
remove the cooler line that pumps to the radiator.
fill tranny with 1 qt. start and let fluid pump out of line removed and shut engine off when fluid stops. repeat till fluid comes out same colour as went in.
button up and fill to spec. take a drive and recheck.
Old Dec 1, 2008 | 02:16 PM
nads1978's Avatar
Thank you VERY much, that is most helpful.
Do you replace the sump plug washer too? or is it not necessary?
How about a filter, is there one? (inside the sump maybe?)
Regards
Old Dec 2, 2008 | 09:24 AM
Davo's Avatar
sump plug washer yes but no biggie really
some carry an external filter like an oil filter to screw out and yes change it if it has one
if not, then it has an internal which should be replaced but only when the sump pan is removed
Old Jan 10, 2009 | 01:29 PM
nads1978's Avatar
After lots of investigating on the interweb I found most the information I needed to do my Gearbox oil change.
http://www.lancerregister.com/showthread.php?t=293023
Old Dec 25, 2014 | 05:08 PM
Liberoz's Avatar
The closest you'll get is the 92 96 Lancer Automatic Trans Manual.pdf which is basically all the same Just fluid level is 8 quarts.
PM me with your email addy and I'll send it to you
seankhan
49
Nov 26, 2019 01:43 AM
mymigi
Jul 25, 2019 03:34 AM
Nawshad
Sep 28, 2016 01:46 PM
EVO VII georgia
12
Feb 9, 2010 10:11 PM
dinsy06
Apr 7, 2009 04:02 PM
