Are these the correct NGK Spark Plugs for Evo 8 ?
Old Dec 2, 2008 | 09:33 AM
Gemnistone's Avatar
Hey Guys,
I went to my local pep boys and told them i have a 05 Mitsubishi lancer evo8. After they searched their computers they came up with these NGK Iridium part number
Are these correct? I remember reading a post that showed a different item number. Want to make sure these are correct before i buy these.
let me know.
thx
Old Dec 2, 2008 | 10:04 AM
MasterNater's Avatar
Stock heat range for the VIII's is 7. It would appear they gave you spark plugs that are 2 heat ranges hotter. If you want to stick with Iridiums, you'll want to get BPR7EIX. A lot of people on the forums recommend going with the cheaper copper plugs, BPR7ES. You have to change them more often, but they are much cheaper and they work very well.
Old Dec 2, 2008 | 10:08 AM
Gemnistone's Avatar
Well im going to get a tune in like two weeks and i wanted to change spark plugs before i get tuned. I would rather just install the iridium ones since i dont have to replace for a while. I heard they last longer, even tho they are 2 x's the price. So i should ask for BPR7EIX and install those correct? I don't need to do any gaping or anything correct?
Old Dec 2, 2008 | 10:13 AM
What kind of mods and how much boost?
Old Dec 2, 2008 | 10:52 AM
Gemnistone's Avatar
currently i have simple mods.
stock turbo
K&N Drop-In Air Filter
Evo 9 BOV
DC Sports 3-Inch Downpipe w/ Cat-Delete, Heat-Wrapped, and O2 bung
Helix 3-Inch Cat-Back Exhaust.
MUSE LICP
Walbro 255 Fuel Pump
Muse Ported Manifold
Ported Stock 02 Hosuing
Ported 10.5 Hotside
Planning to run at a min of 21 psi boost. Dont know if the tuner can go higher or not.
Old Dec 2, 2008 | 10:59 AM
Yes, you'll want to get the BPR7EIX plugs. Iridium plugs usually come pre-gapped but checking them wouldn't hurt. That's the other downside to Iridium plugs; the tiny center electrode makes it difficult to gap them. You'll want a gap of around .026
Old Dec 2, 2008 | 11:02 AM
Gemnistone's Avatar
K cool thx for the info. let me call them and see if they have them in stock.
evovillen
Oct 10, 2013 12:56 PM
Josh@Spec-Ops
12
Sep 12, 2012 08:40 AM
the4g63ftw
May 19, 2010 06:47 AM
stlgrym3
Apr 8, 2010 06:02 PM
Gemnistone
10
Dec 29, 2008 08:31 AM
