Advantage of WG Dump (Vent to Atmosphere)?
Old Dec 4, 2008 | 10:15 PM
BoostLover99's Avatar
[Searched already] - Maybe a stupid question nonetheless
What is the mechanical advantage of using dump tubes to vent exhaust to the atmosphere when the wastegate(s) open?
Why does this seem to be the "preferred" way (instead of reintroducing the exhaust into the exhaust system after the turbocharger)?
Old Dec 4, 2008 | 10:27 PM
jouniu's Avatar
-shorter pipe so it must be cheaper.
-Easier to install?
-cool, old grandmas **** on their pants when you accelerate
Old Dec 4, 2008 | 10:29 PM
fugiwara's Avatar
You didn't search correctly nor search hard enough.
All you have to do is type O2 dump then you'll find related threads.
Here is one for you https://www.evolutionm.net/forums/sh...d.php?t=342112
Old Dec 4, 2008 | 10:35 PM
scorke's Avatar
Less flex/stress on your downpipe/02 dump.
Less backpressure.
Lower EGT's.
Scorke
Old Dec 4, 2008 | 10:48 PM
Jean's Avatar
^ what he said. Supposedly you make a few more hp.
I personally just like how it sounds.
Old Dec 5, 2008 | 06:17 AM
Danner's Avatar
90% of it is sound lol. I love it too I dont think it will effect EGT's noticably granted you have a large enough exhaust.
Old Dec 5, 2008 | 06:23 AM
Import Junky's Avatar
I've been hearing lately that it may help with boost creep......like some of the FP REd owners.
Old Dec 5, 2008 | 11:29 AM
scorke's Avatar
EGT's are heavily dependent on you're tune and turbo setup, exhaust after the turbo has a MINIMAL effect on EGT's
Scorke
Old Dec 5, 2008 | 01:10 PM
Shearer's Avatar
It does help alleviate some pressure in the exhaust system. Higher power set-ups have seen some pretty significant gains when dumping the wastegate.
Old Dec 5, 2008 | 01:27 PM
Oracle1's Avatar
Whats the benefit of having a 0.8 bar wastegate spring compared to having a 1.8 bar wastegate spring?
Old Dec 5, 2008 | 07:17 PM
Thank you for the helpful responses!
Hoojan
Feb 28, 2016 09:34 AM
lostsoulsevo
Nov 19, 2015 04:14 AM
feldguy
20
Apr 10, 2012 06:49 PM
Andrew@AMS
Jan 16, 2012 01:31 PM
Svendiesel
11
Aug 15, 2009 08:24 AM
