new clutch...
Old Dec 7, 2008 | 05:20 PM
ch53avitech's Avatar
new clutch...
My situation... I bought a 03 Evo in April with and Exedy twin disk clutch already in it. It started slipping last month. I don't know much about this clutch, how long it's been in the car, how hard the clutch was driven before I bought it, or who installed it.
My questions:
1. Should I get the rebuild kit or just buy a new clutch (same clutch that's in the car)?
2. Should I get the flywheel resurfaced or get an after market flywheel?
3. Does the Exedy come with a flywheel?
Old Dec 7, 2008 | 05:45 PM
Shacochis06's Avatar
the rebuilds are inexpensive for the exedy twin like no more than $550....all other clutches well be a lil more expensive
Old Dec 7, 2008 | 06:23 PM
But I don't know for sure if the rebuild kit will fix the problem.
Old Dec 7, 2008 | 06:32 PM
silver9mr's Avatar
if your clutch is slippen the rebuild kit will fix that. it will be like having a new clutch again
Old Dec 7, 2008 | 06:37 PM
Chris@nolimitmotors's Avatar
We Have rebuild kits in stock if you need them.
What if I have a cracked pressure plate or something wrong with a spring. It will cost more to fix the problem by trial and error then it would be to play it safe and replace the clutch. Remember, I bought the car used and I don't know anything about the clutch.
Old Dec 7, 2008 | 08:32 PM
althemean's Avatar
The rebuild kit covers all of your concerns. When you pull the clutch you will know if you have a prob with the flywheel. Same thing with the pressure plate. It will all be in your hands to inspect fully.
Dont be scared.
Old Dec 7, 2008 | 08:50 PM
justboosted02's Avatar
get the rebuild kit
Old Dec 7, 2008 | 09:26 PM
TurboTodd's Avatar
Remove the clutch assembly first before ordering anything if its possible. I had 20k on mine and it started dragging on disengagement. I removed it to find a broken spring in my belhousing. I ended up buying new. Good luck...
Todd
Old Dec 7, 2008 | 11:13 PM
red evo8's Avatar
1. take it apart so you know what you are dealing with.
then refer to this thread to order what is needed.
https://www.evolutionm.net/forums/sh...748&highlight=
Old Dec 8, 2008 | 02:17 PM
Thank you all for your responses. I have a better idea of what to do now. Any personal experiences would be appreciated though.
2011EvoXGSR
Nov 2, 2012 06:19 AM
4g63Evo8
13
Aug 15, 2012 10:05 PM
Vivid Racing
Sep 13, 2010 11:49 AM
boostthis89
10
Sep 13, 2009 04:01 AM
freakitgood
18
Jul 29, 2008 02:50 PM
