Crack exhaust manifold = lean fuel?
Old Dec 7, 2008 | 11:09 PM
HxllxMan's Avatar
Hello,
Can a crack in the exhaust manifold make fuel go lean @ wot
The car is being tune for serveral week and everything was fine until the fuel go lean for some reason after several day of e-reflash.
I changed the fuel pump, check for boost leak ect... nothing was wrong.
Until I decided to clean the engine and store the car,waiting for my new FPR... I found a small crack on my DC manifold.
Wondering if this can be the cause?
Thank you.
Old Dec 8, 2008 | 07:18 AM
LV///R's Avatar
Bump,
I'm in a similar situation, instead of a crack, I have a leak and/or possibly blown exhaust manifold gasket. I'm wondering how this would affect my tune until I get it fixed!
Old Dec 8, 2008 | 09:15 AM
cableguy5752's Avatar
In my experience....I had an exhaust leak before the wideband which was causing my A/F to read lean. Open air leaking into the exhaust system caused this. And you could be tuning your car with false information from the wideband. Like giving it more fuel or retarding the timing when it may be just fine. Thus making you lose power.
Old Dec 8, 2008 | 02:20 PM
HxllxMan's Avatar
On the same tune AFR was around 11.0-11.2 with 0-1 knock from 2000 - 8000 rpms.
Till it goes 12.0 AFR wit 6-11 knocks...
I only found out the very small crack 2 weeks laters.
mrfred
26
Aug 30, 2017 01:28 PM
blownralliart
Jul 10, 2017 09:56 AM
4g64fiero
Apr 20, 2017 04:51 PM
KVandy15
21
Mar 22, 2016 04:48 PM
WRC-LVR
Oct 14, 2015 04:12 PM
