tubing for boost gauge
Old Dec 9, 2008 | 01:41 PM
N3VO's Avatar
i bought a prosport mechanical boost gauge and it came with small vinyl tubing for the boost line, i believe its 1/8" but it is not long enough to reach the gauge. i went to autozone, ace hardware and lowes and the smallest they had was 1/4". does anyone know where i could find 1/8" tubing?
Old Dec 9, 2008 | 02:10 PM
genma's Avatar
You could always just get a 1/8" npt to 1/4" barb fitting at a Hardware Store and just run silicone or rubber vacuum hose to the "T" fitting. That would eliminate any issues you might have with the nylon hose kinking.
Old Dec 9, 2008 | 02:47 PM
N3VO's Avatar
well the only problem now is the 1/4 is fine around the tee but around the solenoid on the boost gauge it seems like it will slip off when i am running higher boost. but yeah im gonna check out for some vaccum line see if they have it that small. i think i could just run that all the way through..
Old Dec 9, 2008 | 04:27 PM
DanJ's Avatar
That's strange my autozone had a huge roll of the tubing. They had it behind the counter. The outside diameter was different but the inside diameter was the same. It was like 9 feet for 5 bucks
Old Dec 9, 2008 | 04:29 PM
Psquared's Avatar
throw 2 zipties on where you think it will slip. It won't come off.
Old Dec 9, 2008 | 05:14 PM
N3VO's Avatar
the ziptie didnt feel tight enough around the solenoid i already did it around the tee and thats fine.
95b18ccivic
Oct 10, 2016 12:33 AM
RAY101381
Jun 29, 2012 04:15 PM
Technoz
Sep 19, 2003 06:53 AM
petem
23
Apr 25, 2003 09:28 AM
