Where to get boost gauge tubing?
Old Sep 18, 2003 | 07:46 AM
Technoz's Avatar
hey,
My boost gauge (autotechnics AC S7) came with some hard plastic tubing that connects to the gauge with a compression sleeve and nut. Unfortunately, it's not long enough to reach from the a pillar to the passenger side firewall hole and up to the fpr line. I bought some soft plastic/rubber tubing but it doesn't work with the compression stuff cause its just too soft and slips out.
Does anyone know where I can get more of this tubing? Or a way to use the soft tubing? I've tried pepboys, home depot, menards, hobby lobby and a few others but no one has tubing that small. I saw a post from a while ago that said an aquarium shop might carry it. Any other ideas? Thanks!
Jason
Old Sep 18, 2003 | 07:47 AM
Fireball's Avatar
I just used the hole on the drivers side. There is one, honest!
Old Sep 18, 2003 | 07:50 AM
EVOlmike's Avatar
If you cant find the drivers side hole, just drill a small hole near where the throtle cable goes through the firewall. Thats what I did and it worked great.
Old Sep 18, 2003 | 08:01 AM
Technoz's Avatar
hm, I'll look for that hole fireball, I didn't see it the other night. Can you give me any general directions of where it is?
Also, did you run the line over to the fpr line still? I read in a post that there is a line on the drivers side you can "T" into as well, but wasn't sure if it would be as effective?
Thanks guys!
Old Sep 18, 2003 | 08:05 AM
uranium9v's Avatar
You can use Fuel injected fuel hose...it's stronger than the flimsy stuff and can handle over 50 psi. I got a foot of the stuff for $1 at the auto parts store.
Old Sep 18, 2003 | 08:06 AM
Technoz's Avatar
You normally wouldn't want to tap into the wastegate vacuum line for your boost gauge. There is also another vacuum line source you can use. It sits on top of the valve cover (upper right hand corner) I chose the FPR because it is somewhat hidden and yet still easy to get to. My boost gauge was not installed by Mitsu.
This is what I was talking about from this thread. Would this line work as well (assuming I can find it) if the line still won't reach?
nastea's Avatar
well i posted earlier, WHO KNOWS WHAT HAPPENED.
but i stated that autometer makes a kit that has more hose in it
Old Sep 18, 2003 | 08:36 AM
chinalfr's Avatar
3/16 vacuum hose. You can get it any autopart store. They won't put it at the shelf. So, just ask for it.
Old Sep 19, 2003 | 06:53 AM
Technoz's Avatar
Just for later searches...I was able to get the thin hard plastic hose that came with the gauges at CarQuest. It was actually an oil pressure hook up kit, but it comes with the same tubing as well as fittings. Costs about 5 bucks.
95b18ccivic
Oct 10, 2016 12:33 AM
BaumBizzle
May 10, 2012 03:02 PM
N3VO
Dec 9, 2008 05:14 PM
Aux.
40
Aug 23, 2008 07:22 AM
trinydex
14
Mar 24, 2007 12:30 PM
