Tapping tubular mainfold
Old Dec 10, 2008 | 05:32 AM
frycztech's Avatar
I have a full race manifold and wanted to tap it for my egt gauge has anyone done this? Do i need to weld a bung on?
Old Dec 10, 2008 | 07:16 AM
Q15H's Avatar
Yes, install a threaded weld-in bung.
alex750803's Avatar
Hi, I think you may need to tap it into your downpipe to get the most reliable readings. Depending on where you tap your manifold, you may not get accurate readings from all 4 cylinders. The downpipe is best.
Old Dec 10, 2008 | 07:20 AM
MR Turco's Avatar
If it is stainless i would recommend getting a bung welded.
Old Dec 10, 2008 | 07:43 AM
JakeTheVIII's Avatar
Yes, you will need to weld a bung on. You need to find the right drill bit to use, and make sure you don't drill it too large for the bung.
I believe the correct way to do it on the car is with the car running?? Not exactly sure, but I think the exhaust pressure blows all the shavings out so that they do not enter the exhaust stream.
If you take the mani off the car, this obviously is not a problem.
Oh, and I've always used the runner from cyl #2. Don't know why, but always worked fine.
Old Dec 10, 2008 | 08:34 AM
holiday63's Avatar
Go with a bung
tapped down pipe is always going to read comparatively low temps, but of course you can compensate for low temp reading and still determine if you're running hot.
I would take the mani off if you're going to tap it, sucking any matal particles in your turbo is super risky and not worth the risk.
I've also seen guys tap the manifold without the car running and then using a magnetic tipped screwdriver to accumulate all the metal flakes.
Old Dec 10, 2008 | 10:11 AM
MR Turco's Avatar
people tend to use cylinder #2 since it runs the leanest. I believe for water/meth you want to use a different cylinder however.
Old Dec 10, 2008 | 11:56 AM
cssaddictm4's Avatar
Maybe it is different with meth like you said, but I could have sworn that #1 ran the leanest.
Old Dec 10, 2008 | 12:00 PM
MR Turco's Avatar
i did a bunch of reading before i tapped my stocker and i read cyl 2. And maybe it runs the "hottest" not necessarily the "leanest". I also read #2 wasn't used for water/meth like i said.
Old Dec 10, 2008 | 04:05 PM
aalzuhair's Avatar
cylinder 3 and 4 runs the hottest
Old Dec 11, 2008 | 08:18 AM
frycztech's Avatar
I will be running meth so what runner should i tap i had my stock #2 tapped before but i dont what to mess anything up since i did pay alot for the full-race.
Old Dec 11, 2008 | 10:48 AM
less10's Avatar
I was always under the impression that #3 ran the hottest in 4cyl vehicles.
