GT4094R Spool up
Old Dec 10, 2008 | 07:11 AM
alex750803's Avatar
Cool GT4094R Spool up
Hi, Has anyone used the Garrett GT4094R with the 1.19 A/R on a stock 2.0L Block? I wanted to know what the spool up was off the line. Was the Turbo very laggy and at what RPM does the turbo start to spool at?
I am thinking about buying a Garrett GT4094R but I am not sure what A/R would be best for all out drag racing 1/4 mile. Thanks
Old Dec 10, 2008 | 09:05 AM
ScorpionT's Avatar
I would personally use a 1.06 or .95 housing for better spool, and make sure its with a twin scroll. Spool should be around 4800-5200. Do you already have a manifold or are you buying a complete kit?
Old Dec 10, 2008 | 09:13 AM
alex750803's Avatar
Smile
I was planning to purchase my parts individually and put my build together. I was considering getting AMS Intake and Exhaust Manifolds with a 40mm Synapse Wastegate.
I will be using an Apexi PowerFC De-Jetro ECU for engine management.
Old Dec 10, 2008 | 09:26 AM
ScorpionT's Avatar
For a setup like that, Im not sure how the PowerFC would do mostly because of the injectors required.
Old Dec 10, 2008 | 09:30 AM
alex750803's Avatar
Why do you say that? What Injector setup do you think would be best and do you have any experience with the PowerFC De-Jetro? The PowerFC can control at least 8 Injectors if not more if I am not mistaken. Let me know what u think.
Old Dec 10, 2008 | 09:38 AM
ScorpionT's Avatar
Well, I guess Im not positive on how large of injectors the FC would run, but most piggybacks wont run 1000cc+ very well. For 600+ whp I always prefer standalone.
Old Dec 10, 2008 | 10:17 AM
Touge Factory's Avatar
Power FC is not a piggy back unit.
Power FC is a complete standalone unit. The De-Jetro unit uses MAP instead of MAFS.
It's great, because it comes with a base map of your car's computer.
He won't have any issues using this to tune a car pushing over 600whp.
Old Dec 10, 2008 | 11:55 AM
alex750803's Avatar
Unhappy
How much performance/manageability difference do you think using a twin rail Manifold would make to my build as oppose to using a single rail setup with my PowerFC De-Jetro? I am not quite sure about the logistics of how it works e.g actually connecting the second fuel rail to my fuel line and the injectors to my ECU.
Old Dec 10, 2008 | 02:27 PM
nos51's Avatar
i ran one on my built 2.0.had a twin scroll 1.06 back housing.turbo is very laggy on the street.there alot better options now in t3 configurations that will give a great street and strip turbo....
Old Dec 10, 2008 | 04:21 PM
Spoolin18's Avatar
I wouldn't even think about running this turbo on a stock block. You would be much better off running either a standard 35R or an HTA. Either of those units are capable of maxxing out the stock block and then some..
Old Dec 10, 2008 | 05:39 PM
rxw's Avatar
rxw
Get a twinscroll 4088r from full-race and enjoy an awesome power band! 4094 will give you LOTS more lag and not a huge amount more power.
Old Dec 10, 2008 | 08:21 PM
less10's Avatar
I just sold my 4094r that was on my honda, I was going to put it on my evo but after seeing many dyno graphs and hearing alot of "horror" stories. I decided to just go with a twin scroll 35R with a 1.04 ar. So it will have plenty of spool and great top end power.
Old Dec 11, 2008 | 06:30 AM
Steve93Talon's Avatar
Funny, I've seen the exact opposite. Local DSMer had a 4088R, swapped to the 4094R, barely noticed a change in spool and gained decent power. He's currently running the FP HTA88 which outspools and outpowers both of them though.
I'd also consider the Borg Warner S366. cheaper, capable of just as much power, spools well for it's size.
Old Dec 11, 2008 | 07:09 AM
Ev0cRaZy's Avatar
Well notcied he said TWIN SCROLL 4088
Old Dec 11, 2008 | 07:26 AM
Sharkbite2000's Avatar
How much power are looking for to be happy ?
The 850R spools faster and makes the power.
