Clutch Question Exedy vs Cusco
Old Dec 11, 2008 | 01:06 PM
xpehbam's Avatar
I recently got Cusco twin disc and it needs a new pressure plate. Does anybody know if Exedy Twin HD has the same pressure plate as Cusco twin?
Old Dec 11, 2008 | 07:28 PM
althemean's Avatar
I am almost positive it does. The clutch discs themselves are marked Exedy. Check with some of the vendors here. Quite a few sell rebuild kits. Or try a search on rebuild exedy clutch. That should point you in the right direction.
I have the same clutch BTW.
Old Dec 12, 2008 | 07:52 AM
xpehbam's Avatar
I spoke with few vendors on here, and none gave me an answer. One even called exedy but they say its different, they don't say how different. $500 is a lot of money to gamble on this one.
Old Dec 12, 2008 | 09:19 AM
althemean's Avatar
do a search for triple plate conversion...that had PN's in it.
Old Dec 12, 2008 | 10:55 AM
xpehbam's Avatar
It looks like twin to triple conversion might not work for a cusco twin
Old Dec 12, 2008 | 11:17 AM
jmelocik's Avatar
The Cusco twin is the same as the Exedy SD, not HD. Bare that in mind when looking at different stuff for them.
Josh
Old Dec 12, 2008 | 07:49 PM
althemean's Avatar
here is a quick link.
http://lancershop.com/customer/produ...=95&page=&js=n
The SD vs HD should still have the same bolt pattern. Its only a clamping load. Trust me about the guts though. The clutch disks themselves say "exedy" on them. The Cusco unit is nothing but a rebranded Exedy.
Dont forget a clutch alignment tool while you are at it.
Old Dec 12, 2008 | 10:20 PM
althemean's Avatar
https://www.evolutionm.net/forums/dr...onversion.html
This was performed on a twin Cusco to a tripple plate. Although when I read it the clutch was a carbon/carbon so I dont know what the difference is on those. But there are many helpful PN's and vendor references in there.
Old Dec 15, 2008 | 07:48 AM
xpehbam's Avatar
Thanks for a great link!!!
