? about ultimate racing test pipe
i was reading on lancershop.com that this test pipe doesnt cause a CEL when you install it and its really cheap! doesnt anyone have this on their car and what are your opinions? thanks
The CEL can be defeated with a $3 spark plug non-fouler or by disabling it with ECUFlash using a Tephra hack. How is $93 for a testpipe cheap? My favorite testpipe is the resonated Megan and it can be had for around $60. Also, do some searching on LancerShop; you should avoid doing business with them like the the plague.
http://www.maperformance.com/megan-r...-pipe-evo.html
haha why is this company bad lol? and what exactly is the resonated one? i want the most power possible so i just thought the test pipe is the best option. i was planning on getting a perrin o2 simulator because ive never heard of the o2 fouler option. ill look into the megan one
LancerShop is bad b/c they continually rip off customers, send the wrong products, refuse to issue refunds, etc.
A testpipe is your best bet for making the most power. The Megan resonated testpipe is just nice because its cheap, it works very well, and the resonator in it helps quiet down the exhaust a bit.
ill help you out alittle man before they close this post lol.
USE the search function to find your answer if you want a Complete guide on the 3 dollar Non Fouler method its actually more lol depending on where you live I have a complete guide to that and other installs on my cardomain page i explain how to do it from beginning to end
http://www.cardomain.com/ride/3123213/4
hope this helps
hope this helps
well i think the megan resonated one is for me then. i like a sporty exhaust but id rather it be a little quieter without losing power. and i would rather buy a new cat pipe but thanks for the offer
. where can i get a perrin o2 simulator and is it hard to install? do i still need it even if i am getting a tune right after i install it?
hope this helps
hope this helps
Get this: https://www.evolutionm.net/forums/ec...d-v5-10-a.html and you won't need the non-fouler since you can just disable rear o2 sensor CEL with a simple flash. If you aren't able to do this yourself your tuner definitely will be able to.
oh cool so i dont need an o2 simulator... because my plan is to install all of this stuff on my own, take the ECU out drive a different car to my tuner with the ECU, get it flashed to match with the parts i have installed, drive home and put the ecu back in and start my car up! i will do a full dyno and custom tune once i get my bigger mods in like cams, turbo and intercooler.
well i plan on putting intake, catless turboback, intercooler pipes, fuel pump, o2 housing, boost controller and bov in so i shouldnt drive it to the tuner with those mods and no flash right? i dont want to mess up my baby
custom manifold
aps intercooler
new sparkplugs
injen intercooler upper pipping
injen lower intercooler pipping
injen airintake
3" Invidia N1 High preforamce exahust
3" Perrin Downpipe
TestPiPe
Forge MBC
Perrin Oil Catch Can
Sunpro Boost gauge
255 Walbro Fuel Pump
Mistohmoto high Preformance Radiator
O2 Non fouler bypass
New blue Xo radaitor hose
Painted Calipers
Future Mods
New BBK Full or Fp red turbo have not decided
NOW MY CAR IS UNTUNED. I have not tuned it once since i got it. My car drives fine. The only thing is im not getting the full preformace i can out of my car. My nearest tuner is 5 plus hours away and thats mellon. So im not gonna go see him until i get my car full decked out new turbo and br head and then greddy camgears and Kelford Camshafts then ill get it tune.
The only thing that might happen is a drop in idle alittle of than that im not tuning for every preformace part i put on so there your car will be fine
