Piston Comparison
Old Sep 5, 2014 | 04:05 PM
  #151
JohnBradley's Avatar
Originally Posted by Migsubishi
11.8:1 sounds good, what say you Aaron?
The K668 pistons will be interesting to see how they tune out.
Old Oct 27, 2014 | 09:33 AM
  #152
kikiturbo's Avatar
Here is wiseco K669M86AP, which is a 1400HD 10.5 stroker piston, however it will soon run in a 2050 CC std stroke g63 156mm long rod with aprox 9.4 - 9.5 CR on pump.
I know the jury is out on LR but I wanted to try some higher CR on pump and while Wiseco doesn't officially list this application I stumbled upon in by accident..
Attached Thumbnails Piston Comparison-20141027_171522.jpg   Piston Comparison-20141027_171541.jpg   Piston Comparison-20141027_171856.jpg
Old Oct 27, 2014 | 10:35 AM
  #153
mrfred's Avatar
Looks tough.
Old Oct 27, 2014 | 12:57 PM
  #154
kikiturbo's Avatar
ha, talk about part matching.... this is probably a 1000 hp piston set and a 500 hp rod set..
I am cheap, I know..
Old Oct 27, 2014 | 03:52 PM
  #155
mrfred's Avatar
Isn't that the Turbo Tuff rod that's got a great track record in mid 700 whp builds?
Old Oct 27, 2014 | 10:36 PM
  #156
kikiturbo's Avatar
no, this is the wimpy H beam rod.
Old Oct 28, 2014 | 02:55 AM
  #157
I think the jury convened on rod ratio years ago
Old Oct 28, 2014 | 03:57 AM
  #158
kikiturbo's Avatar
depends on which side of the pond you are sitting..
Frankly speaking, I will not notice the difference but am sure having fun trying..
Old Oct 29, 2014 | 08:17 AM
  #159
There is no difference in power nor torque between a short rod or long rod motor. The long rod/long stroke motors are smoother and less vibration prone than the short versions (i.e. LR2.4 vs 2.4) but still do not make any more power. A LR2.0 may have, and I mean probably not, less reciprocating weight but it is likely that the 30-40g saved in the piston is more than made up for in the rod.
Old Oct 29, 2014 | 09:19 AM
  #160
kikiturbo's Avatar
I agree completely that in my application it makes little difference (I will run it up to 8000 RPM) but it is an option I wanted to explore and try out while going for a bit more CR (which is the main idea..).. A lucky result was that we found an off the shelf solution from wiseco that is not listed officially and might be interesting to others.. 2.0 LR is quite popular in the UK..
The piston weight is 326g I believe..
Old Oct 29, 2014 | 09:20 AM
  #161
kikiturbo's Avatar
BTW, thx for the rings, they are perfect.. thumbs up for service..
Old Oct 29, 2014 | 04:19 PM
  #162
The heavier HD2 casting may be, I know at one point they were down around 309g and the 2.3 piston (more or less the LR2.0) was around 285. They may have gained some weight after being revised though.
Old Feb 25, 2016 | 09:59 AM
  #163
honki24's Avatar
For the 4B11T Anyone know advantages/issues with Weisco vs Manley pistons? I'd like to do 10:1 SCR and want to be sure I'm getting a piston design with good quench, ring sizing/placement, and wrist pin location. Know where I can find pictures? I'm going to do a bored/stroked 2.4L but I'm weighing out the BAMF (buschur with Manley and Darton) vs the MAP (Weisco and LA Sleeves).
Old Jun 6, 2018 | 07:06 PM
  #164
2006EvoIXer's Avatar
How did this asymmetrical piston/rod combo work out?
Old Jun 7, 2018 | 02:34 PM
  #165
xRoguex's Avatar
also interested
