front o2 sensor replacement
Old Dec 23, 2008 | 05:14 PM
zeus1's Avatar
so i had a buschur ss o2 housing installed on my car. the front o2 sensor was very difficult to remove and was most likely "disturbed" during removal but it was reinstalled with the hope that it would be ok. the car has 75k on it so no biggie. however i am getting the p0134 code and also did logs getting no feedback from the front o2 sensor. i will replace it myself since it looks fairly straight forward. any tips or advice or thing to look out for?
Old Dec 23, 2008 | 06:09 PM
funks's Avatar
One tip I guess is that the EVO 9's use a different front O2 sensor than the EVO 8s..
You can get the front EVO 8 O2 sensor cheap @ oxygensensors.com (79.90$) - it's plug and play w/ the correct harness.
Old Dec 23, 2008 | 06:27 PM
def1's Avatar
make sure u disconnect the battery. i got that same code when i did my 02 install. i disconnected the battery and it was perfect after that.
Old Dec 23, 2008 | 06:36 PM
Mitsutech56's Avatar
pick up a thread chase for the O2 threads 18mm x 1.5. If the sensor is tight, chase the threads and use anti-seize on the threads of the new sensor. Make sure you don't contaminate the sensor end with the anti-seize. Good luck.
Old Dec 23, 2008 | 06:40 PM
justa4banger's Avatar
i bought the universal from autozone and it works perfect....
Old Dec 24, 2008 | 06:15 AM
zeus1's Avatar
thanks for the help!
Old Dec 24, 2008 | 06:37 AM
getsideways's Avatar
BUY THIS SENSOR ^^^^^^^^^,,,,, Do not buy the auto zone carquest napa whatever universal sensor i have one in my garage you can have if you want they dont work well you may not notice it unless you log but when i did my afrs were jumping all over even at cruise you couldnt feel the difference but mileage was affected whereas the one from the above web site worked like factory no splicing required and the AFRs were perfect.
Old Dec 24, 2008 | 07:25 AM
jmelocik's Avatar
Check out mitsubishi parts.net also same price and you are actually getting the same as OEM with the correct connector just like the above. If you have the employee pricing code you get a nice discount until Jan 09 (short time left). I am NOT a vendor for them just had good luck purchasing from them. If you call you can usually get them to waive the shipping cost also.
Edit: here is the link http://www.mitsubishiparts.net/cart/?pn=md164423
2nd edit: employee pricing code: h7sNt0ho
Josh
Old Jan 7, 2009 | 05:42 PM
4G63's Avatar
Josh
Is this for an 8 or 9? My sensor is shot and I'm looking for the part # for it. Its under warranty, but the dealer was busting my ***** about my catback and K&N drop-in.
Old Jan 7, 2009 | 05:53 PM
VRSF Tiago's Avatar
+1
But if you can get the OEM from Russel for the same cost I'd go with that
Old Jan 7, 2009 | 06:01 PM
brp's Avatar
brp
I have an OEM front o2 sensor for sale that i just took off my car. its in perfect working condition but i dont need it anymore as i am running a standalone ecu but PM me if you are interested with an offer.
Old Jan 7, 2009 | 06:08 PM
MitsuJDM's Avatar
Try clearing the code. If it doesn't come back and it shows that it's doing it's job in your logs, then don't worry. If it comes back, replace it.
Sometimes things are weird if disturbed. I changed my timing belt and got a P0300. I cleared it and haven't seen it in over a year. It's worth a shot.
Old Jan 13, 2009 | 11:12 PM
Colt4g63's Avatar
Josh
I looked up the part # to the front O2 for an EVO 8 and its MN153010. The link you just gave isnt the same part #.... My o2 is bad and i need to replace it so can anyone clarify this for me? I really dont want to have to spend nearly 300$ on a O2 sensor.. thats just rediculous!
DONNOD
Jul 22, 2016 05:16 AM
JohnDoe1984
Nov 11, 2011 07:24 PM
mostro
Jan 27, 2007 03:55 PM
FiftyFive
Dec 19, 2006 10:54 PM
snake679
May 23, 2006 12:59 PM
