fuel injector size
Old Dec 29, 2008 | 07:44 AM
ch53avitech's Avatar
fuel injector size
My future build plans are red, kelford 272, meth injection (only because I don't can't get race fuel where I live), and the mods in my sig. Along with ported 65m tb, ported intake manifold, and ported exhaust manifold.
With all that said, what size injectors should I run. My tuner said I should get 680s or 780s. I wanted to get more input. And I was getting PTE injectors, are they any good?
Would I benefit from a double pumper?
Old Dec 29, 2008 | 07:50 AM
cpoku's Avatar
780s
double pumper is not needed unless you are shooting 500whp+
What are you building for? Road Race, Drag Race or just a nice DD...
Old Dec 29, 2008 | 07:51 AM
2k4EvoVIII's Avatar
http://www.rceng.com/technical.aspx#...tor_Worksheet_
Bottom of the page is a calculator
Old Dec 29, 2008 | 08:06 AM
sparky's Avatar
The 780`s will be O.K. for the Red plus meth. But, they`d be only marginally sufficient for the Red and 93 octane at the higher boost levels(26 PSI+). I would do the PT&E 880`s for the Red. These will provide sufficient headroom should you ever want to run a high boost non-Meth ECU map(race gas). If you eventually run corn gas, then you`ll want 1000`s, or a 1200`s, as well as a double pumper. The single Walbro is good for a bit more than 525 WHP(non-oxygenated fuels).
Old Dec 29, 2008 | 08:40 AM
Gary@MellonRacing's Avatar
by it once buy it right go for 1000
Old Dec 29, 2008 | 12:58 PM
travman's Avatar
yeah I agree........FIC 1050's are super nice and if you ever want to run e85 or further upgrades you have that option and your fuel system is already setup.
Old Dec 29, 2008 | 01:02 PM
DDATuned's Avatar
+1
Old Dec 29, 2008 | 04:15 PM
Originally Posted by cpoku
780s
I want a bad a$$ street car /w weekend drag races.
Old Dec 29, 2008 | 04:17 PM
With meth?
Old Dec 29, 2008 | 04:29 PM
cpoku's Avatar
Then just as sparky said 880 pump/meth(with out winter o2 gas) or 1000 for eth (e85); if you start running out of fuel (maxing your injectors) then go double pumper.
Old Dec 31, 2008 | 10:33 AM
Who has low prices on fuel injectors? I was thinking Vivid.
Old Dec 31, 2008 | 10:38 AM
silver9mr's Avatar
good info im loking into new injectors too
Old Dec 31, 2008 | 11:34 AM
CO_VR4's Avatar
The FIC injectors have a very nice spray pattern compared to the others. I'd suggest you look at FIC's website www.fuelinjectorclinic.com for the pictures of the comparison.
I agree with the previous poster who said get (at least) the 1000s and do it once. With the 1000s, you'll be at 70% or so of injector duty cycle, and that gives you plenty of headroom to allow the injectors to do what they are supposed to. Above 80 or 90% IDC, you have less control of the injector's flow characteristics, and that is to be avoided. I've run 1000s with the Red on gas, and hit about 70%. If you're going E85, you'll need at least 30% more fuel, and that calculates out to 1150s or 1200s.
FIC also flow matches their sets of injectors to less than 1% variance, and provides flow sheets with your set, so you know exactly what you're dealing with. That's a nice benefit.
Old Dec 31, 2008 | 11:48 AM
JakeTheVIII's Avatar
A double pumper increases the max capacity of the same set of injectors?
Old Dec 31, 2008 | 12:10 PM
How does Precision compare to FIC? I thought I remember reading someone having a hard time fitting the FIC injectors on the intake manifold. There was something wrong with the clearance or something like that. I could be wrong though.
