ACD Removal
Old Dec 30, 2008 | 11:09 AM
1320awd's Avatar
ACD Removal
So here is my question. I am currently wanting to get rid of my acd pump from my 06 MR. For weight and also for room on my intercooler piping. So can I remove this and just keep fluid in the transfer case and drive like normal?
I will be swapping out later to a non ACD transfercase when I upgrade one.
Peoples input would be great.
Old Dec 30, 2008 | 11:17 AM
vboy425's Avatar
the right way will be non ACD transfer case.
Old Dec 30, 2008 | 11:19 AM
1320awd's Avatar
I know that but I'm spending way to much money on this build already and I really dont want to spend the money on one yet.
Old Dec 30, 2008 | 11:45 AM
Billy@EnglishRacing's Avatar
Then leave the pump in until you put a non acd case in there. Start saving up. On the bright side once you but the non acd case you can sell the old case and pump to recoup your money.
Old Dec 30, 2008 | 11:49 AM
1320awd's Avatar
There is no room for the pump due to the size of my intercooler piping 3.5" on the cold side.
Old Dec 30, 2008 | 11:53 AM
Looks like you need to buy a non acd t-case sooner then later then
Old Dec 30, 2008 | 12:32 PM
1320awd's Avatar
Yes I am thinking that may need to happen, what will happen if the 06 one is used and just plugged off with the fluid inside.
Old Dec 30, 2008 | 01:11 PM
Gary@MellonRacing's Avatar
cant u switch everything to the rear like the evo 7 .... i have one and everything is in the trunk man
Old Dec 30, 2008 | 02:54 PM
JohnBradley's Avatar
It becomes an open diff and you do sweet front wheel burnouts until the drivetrain catches up. You have to either run it or go to a non ACD...no in between...OR relocate the pump assembly like the rally cars do.
Old Dec 30, 2008 | 02:57 PM
1320awd's Avatar
Going to sell the Transfercase and just buy a Rs non ACD transfercase from Mike@awdmotorsports... thanks all for your input
Evo47
Jun 15, 2016 07:38 PM
BuiltS13
18
May 23, 2016 08:04 AM
RussellDaniel
Mar 28, 2016 10:07 AM
rodent
Sep 28, 2010 10:40 PM
WillEatUrSTi
17
Feb 23, 2006 11:51 PM
