Weight difference Between ACD and non ACD
Old Dec 19, 2014 | 04:11 PM
RussellDaniel's Avatar
So reading through the threads i was looking for exact weight reduction from removing ACD pump,bracket, lines, and going with a non ACD case. All i have been able to find is a 25lbs weight reduction simply removing the pump. Does anyone have a exact weight reduction for removing the case, brackets, lines, and having a non acd case? I know the non acd case has to be lighter due to the fact it isnt filled with ACD fluid and clutch packs for the ACD. Ive dug through the weight reduction thread with no luck. If anyone knows please share the wealth.
Old Dec 20, 2014 | 08:13 AM
bump....????
Old Mar 22, 2016 | 11:59 AM
Well if anyone is interested, i weighed my car before and after, the diff was about 30lbs.
Old Mar 24, 2016 | 08:57 AM
nemsin's Avatar
Good to know. I too am a fan of the 04 RS non-acd transfer case.
Old Mar 24, 2016 | 09:48 AM
LetsGetThisDone's Avatar
Did you compare the weight of the tcases? I feel like a lot of the weight is in the pump and reservoir. The viscous coupling isn't exactly light..
Old Mar 24, 2016 | 10:37 AM
TheBoz's Avatar
That 30lbs sound about correct, when you add the pump, pump bracket, relay, wiring, acd ECU, hard lines, soft lines, nuts bolts and other hardware.
But the transfer case alone would not be much, 5-10lbs, depends if you are talking the open diff or the LSD diff.
Old Mar 28, 2016 | 10:07 AM
Exactly, that was the total weight savings after everything was removed.
NOMIEZVR4
Oct 18, 2013 01:28 PM
Manny1020
Apr 22, 2012 06:09 PM
EE
Nov 13, 2007 03:33 PM
nightfire115
Jan 31, 2005 04:56 PM
